DeepGroove
- Feb 13, 2013
Any news regarding the add-ons?
I purchased this Sprint Moto E 2nd Gen with a microsd slot. It has NATIVE Android USB audio so you don't need UAPP to listen from the Mojo. Google Music works just perfectly like on my Nexus 6. It's on sale right now too for $39.99 shipped:
30$ on taobao.
I had the same problem with cover art but my friend and iTunes guru, bflat taught me. Double click on the album in iTunes scroll down to "Get Info". Then click on "Artwork" and double click on the album art displayed and click on "Delete Artwork". After that, click on "Add Artwork" and add a previously downloaded JPEG of the proper album art and click "OK". A bit cumbersome but that should solve your problem of the album artwork.
Hey guys, my Mojo gets really really hot when used as a desktop amp with power plugged in. It has been connected to power, I originally let it charge and then I have had it plugged into power consistently for the last few weeks since buying it. I read in the thread that this unit is safe up until 150 degrees, which I'm hoping is indeed the case, but right now, the unit is about as hot as holding a mug with boiling water in it, it's almost a tad too hot to touch.
Is this something I should be worried about? It does have me concerned to be honest :')
I appreciate your thoughtful response but I don't think this will work since the files are not even in iTunes. I have them all in Jriver. I don't use iTunes at all other than to drag and drop folders of music into the Onkyo app from my music folders on my hard drive so my iTunes library is completely empty. This it's a mystery why some art appears and other art does not.
Hey there anyone else having problems with UAPP 2.43... MOJO CAN T GET CONNECTION NO MORE!!!! NOOOOOO
facing an issue here, not sure if it's covered under warranty
I use my mojo/dap stacks as portable, they are kept in my messenger bag while commuting
recently i notice the sound is breaking up whenever there is movement
i hv checked with several cables and able to pinpoint it to the mojo coax jack, when I twist the cable around while plugged in, the sounds breaks (power button light on the mojo flickers)
it does not happen on the X5 coax out jack. I hv tried switching both ends/3 cable types
mojo > fiio L17 > X5
being a portable, I kinda expect the L17 will be 'pushed' around a bit while in my bag
@faran
https://detail.m.tmall.com/item.htm?id=39264953184
Or you can search on taobao "AK100 金属"
The metal bumper case will not solve your problem as it is only around, does not cover the back.
