Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
593 594 595 596 597 598 599 600 601 602
604 605 606 607 608 609 610 611 612 613
  1. masterpfa
    No. Each HP will operate at their own levels. So for example if having IEM's and HD800 connected, at level that suit the IEM's you would not hear much on the HD800's or worse if you were to listen at levels acceptable on the HD800's you would probably do serious damage if you tried to use the IEM's
    IMO yes.
  2. LouisLoh
    Thanks. Is there any workaround so that another person with different headphones can enjoy output from the same Mojo at the same time as I am, with volume matching?
  3. uzi2
    You would need a volume control (variable inline resistor) on the cable with the most efficient headphone.
  4. lurk
    Looks like the input jacks side got a few jacks blocked by the case (like the official case for hugo)
    davidmolliere likes this.
  5. Whitigir
    Damn...couldn't believe how much I was :caught" by Mojo "black-ness" in the back ground ...I miss it, wish there is other dap out there that offer this kind of blackness
  6. linzheng
    It is custom made, you can make it without the flap(tight fit) or the flap blocking the 2 USB ports. I personally don't need coaxial and optical hence the way it is.
    It's only $30, you can always buy a few different designs in case you change transport in the future.
  7. Angular Mo
  8. simonm
    There's some merit in this.  Mojo is able to wring every last drop of quality out of whatever it's given and the results I've found with iTunes AAC are pretty good, better even than lossless with a ****tier DAC.  Of course, that doesn't mean I'm happy with compressed music when I can get CD or even higher quality for the same price or less (as is often the case).
    Obsessive audiophiles want the best.
  9. stevemiddie
    Mojo brings out the best of David Bowie.
    RIP David.  Love forever
    canali, Mython, Angular Mo and 3 others like this.
  10. Reignfire
    Is it perfectly safe to use Samsung's Adaptive Fast Charger (up to 2.0A) in charging Mojo? Any official advise from Chord?
  11. ken6217
    $16.00 month if you prepay 6 months. The sound quality is excellent.
  12. Rob Watts
    Yes so long as it is a PSU for USB, the current can be as large as you like, it just needs to be 1A or more.
    Rob
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
  13. Dobrescu George
    Of course, Mojo + mp3 at 320 will sound better than FLAC + a bad dac/amp of the same song.
    I will still use lossless versions of everything I am able to fiind in lossless (some music is exceptionally hard to fiind)
  14. howdy
    can someone use the VOOC rapid charger from the Oppo HA2 for the Mojo? I assuming yes from your statement.
  15. ChordElectronics
    Although CES has now come to an end, we had a lot of fun. One of our top moments was when Graham Nash entered the room and listened to Mojo. His words were 'I was in the studio with Neil Young when he recorded this... Now I'm back in the room'.​
    Stereophile covers this excellent moment with a dedicated article: http://www.stereophile.com/content/graham-nash-tries-out-audeze-el-8-headphones-and-chord-mojo#4LIvyd3bP0sspyI0.97​
    Mython, uzi2, Feedbacker and 4 others like this.
