- Feb 11, 2008
As an aside, there is a dedicated section on Mojo battery and charging, in the 3rd post.
Some would say that's a better physical (and aesthetic) fit with the Mojo, anyway.
If using an AK with a Mojo, the only real downside of a 100ii, vs the 240, is probably lower downsample for DSD (over optical), and memory capacity (256gb internal + 1 slot vs 64gb internal + 1 slot.
Fortunately, 200gb microSD cards are now getting more realistically-priced, and there are many happy AK100ii + Mojo owners in this thread
So, here's wishing you happy listening!
I very strongly take issue with iRiver's pricing, but now that AK100iis are fairly priced, I personally have no issue with the AK100ii
.... I'm just waiting on the ak to charge
Yeah I fear you're correct. well maybe the guys from USBAPP will figure out a way, since there are a lot usb options... But none works for me, yet.
Other question, is there any hope, that the Tidal integration is going to be improved? Like having access to the same navigation like in Tidal, with options to go back after you chose an album
Also I am looking for a case for mojo... And still a USB cable for portable use... Something like the moon audio silver dragon form fit... For a realistic price.
I recently wrapped-up a week long audition period with Mojo and summarized my thoughts in a review. LINK.
TLDR: I'm a bit DAP obsessed, and Mojo made me question that obsession. Simply fantastic little device. Still can't believe the sound @Rob Watts
and the team at Chord pulled off with this little guy!
\m/ \m/
Mr Rob Watts explained how the charging circuit works when the Mojo is left plugged in. I added it to the Mojo Issue Solutions thread.
Rob Watts explanation was post 4596 last time I looked. I didn't note down the page number. This is what he said exactly:
"Just to clarify. Charging is automatic. If you are playing and charging at the same time, with a fully charged battery, the charger will supply enough current to balance the consumption used by Mojo, so no net current into the battery. If its fully charged and the unit is off, the charger will go off. The charger will re charge automatically when the battery voltage falls to 8.2v (off at 8.4v) so keeping the charger connected will ensure a full charge."
Good review. I'm probably going to pick one up this week.
I'm curious with your love of DAP's how you never mentioned A&K in your auditions or for your own personal listening.
I was wondering, I have a cozoy astrapi and it comes with a micro usb to lightning cable. Can it be used with the mojo? Seems plausible
