Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
464 465 466 467 468 469 470 471 472 473
475 476 477 478 479 480 481 482 483 484
  1. T1000
    Amazing sound with Mojo and Ak380 and Angie, this Mojo is really a bargain and did´t expect that it is so good. [​IMG]
    Light - Man likes this.
  2. mscott58
    QQ - How would you describe the difference of the 380/Mojo combo compared to the 380 solo? Cheers
  3. singleended58
  4. Angular Mo
    I don't know about the blue-ray player having such a setting, I will take a look...thank you.
    The only other cable I have attached to the player is the HDMI one, for video purposes.
    However, that does not explain why I have no throughput from the iFi Nano which should act as a converter.
  5. T1000
    The 380 has a more relaxed presentation, more fluid, the mojo is very musical and especially the vocals become more upfront in the mix.
    It´s very fun to listen to and i like the mojo more than hugo i owned before.
  6. salla45
    It looks like a 4 pole cable, the input to the mojo should be 2 pole, i believe? I am using a 4 pole out from my X3ii but into the mojo it's 2 pole.
    Works fab.
    Angular Mo likes this.
  7. Light - Man
    Good to know, have you compared your Samsung S5 phone Vs the X3ii into your Mojo yet?
  8. tkteo
    Well spotted. The 3.5mm plug portion of the cable that Angular Mo bought certainly looks and I would say it 4-pole.
    Is this what it meant by "TRRS" termination?
  9. Ike1985
    I've had no issues with mojo & iPhone 5 w/Onkyo HF until now. Mojo has been giving me the correct pinkish-silver DSD light when playing DSD files in onkyo but today while playing a 5.6mHz DSD, Onkyo converted it to 192kHz PCM. Anybody know what's happening? image.jpg
  10. Angular Mo
    @salla45, thank you !
  11. Ike1985
    What the heck, now it's putting out DSD, I didn't change anything. image.jpg
  12. Sound Eq
    i am happy to see the starter of basshead thread is liking the mojo :)
  13. Mython Contributor
    "It rubs the lotion on it's skin..!"
  14. Uyski
    Got my Mojo, and I'm extremely satisfied with the audio quality.
    However, the USB ports on my unit are defect. Small movements will disconnect the mojo when it's charging, or used as dac, so I guess the usb ports are loose.
    Too bad I will have to return it. Bumping into it while using my macbook will disconnect it, so using it portable with my S6 edge will be impossible.
    Anyone that have heard of this issue?
  15. singleended58
    Mojo's USB input for CCK from iPhone 6+ is acting up yesterday (did not have loosing problem at the beginning). However, I mostly listen to AK100mk2 via optical which I like the SQ more...
