Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
459 460 461 462 463 464 465 466 467 468
470 471 472 473 474 475 476 477 478 479
  1. PAM005
    I use a very thin interconnect, so there's almost no weight on connector. Besides that, connector is almost on bottom of "table" (3mm) - so if you use a small piece of "foam" under the connector, pressure is almost ZERO :wink:!
  2. Wyd4
    Perfect thanks :)
  3. Hawaiibadboy Contributor
    Sometimes the hype is just that....hype.
    So don't get ruffled when folks see all the hoopla and over the top descriptions and cast a wary eye on it.
    That wary eye makes it bit more special when the item matches the hype.
    I took this pic with the IEM still in my ear. That pretty much says it all.
    I'm not interrupting a 24/192 of Aerosmith's - (Mama Kin')  just to take a pic. I can do both at the same time
  4. x RELIC x Contributor
    So......you're enjoying it. Glad to see you gave it a shot.
    Hawaiibadboy likes this.
  5. Chefano
    Just buy an Ipad charger.
    Its noise is and ripple are really low
  6. Light - Man
  7. Sound Eq
    so what u think my freind, does it make sense now that when i say something is great it means it is, I was thinking what u would say, but i am glad u followed the gang
    as its a great device to loose on getting it
    AndrewH13 likes this.
  8. Sound Eq
    wish for a universal case to attach different size phones to the mojo, what do u think guys can we ask a case maker to look into that
    as the mojo with a mobile qualifies it to being portable, we just need a case that can attach different sizes of phones
  9. x RELIC x Contributor
    Have you seen this from earlier in the thread? Looks quite handy.
    http://www.head-fi.org/t/784602/chord-mojo-the-official-thread-read-the-third-post-for-updated-info/2925#post_12033020
    Angular Mo likes this.
  10. Sound Eq
    man ur ak240 seems to have been roughed man , poor ur ak240
  11. raelamb
    Just got my lavri cable yesterday and damn it looks sweet. Unfortunately hooking it up to my mojo and ipod touch running 9.2 produces wonky results. Sometimes when turned on the on/off ball cycles through all colors and then settles on red even with hi rez content and won't play. Anybody using this cable have any advice? Thx
  12. pinoyman
    isvthe fiio l19 already out for thr apple products?
    Sent from my iPad using Tapatalk
  13. Ike1985
    So then the best files to seek out to get the best sound quality out of the mojo are the highest bit/sample rate flac files? The highest i've seen is 32/192.
  14. Uyski
    How did it match up to the FiiO X7 you reviewed?
    I was planning on getting a X7, but after watching your review, I settled for using my S6 edge+ with mojo instead.
    The mojo arrives tomorrow so I'm very hyped.
  15. Schubida
    How well does the mojo match to the AKG K812? Thanks for your answer!
