Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
456 457 458 459 460 461 462 463 464 465
467 468 469 470 471 472 473 474 475 476
  1. mscott58
    Can be very loud, but is highly dependent upon the HP's you're using.
  2. elnero
    11
    x RELIC x likes this.
  3. Hotwire
    That's a relief! It's 11 or nothing.
  4. joshk4
    Ahh I see... Yeah I'm not sure why it's claimed 10. I most likely am hitting half that at 5 pretty much from the start.
  5. elnero
    [​IMG]
  6. joesmokey
    Unfortunately the issue persists when listening on iOS devices through the CCK.  Is it unrealistic to expect a driver fix for iOS devices, since we are limited from adding silence padding?
    (Apologies if this has already been addressed.)
  7. twelvebears
    It can put out 4volts, which is as much as the Lotoo PAW Gold. Unless you want to go deaf or own a pair of Hifiman HE-6s I don't think you will short of volume.
  8. x RELIC x Contributor
    Actually it can output 5.3Vrms (and I believe it does 7V peak). Lots of power.
  9. sabloke
    Just got an e-mail from the retailer, the JitterBug is out of stock so it won't be delivered until early January. Pretty pissed off as they were showing stock when I paid! Bummer...
  10. imattersuk
    Amazon UK have 2 in stock, where are you located ?
  11. SearchOfSub
    I wouldn't be so pissed. I had the jitterbug and returned it. It does give a little bit more refinement and soundstage did seem to get wider but it was at the cost of me not being able to get closer to the performance. It took way resolution.
  12. joshk4
    Hey guys,
    When it is charging, does the white light stays on for 3 seconds, then turns off for 3 seconds and repeats?
    Or should the white light stay on always when charging.
  13. singleended58
    White light stays on until fully charged (it will be off).
  14. joshk4
    Thanks,
    Mine just blinks (but blinks in 3 seconds)... so 3 seconds white light, then 3 seconds no light and so on.
    I pulled it out and connect it to listen and its blue light. Not sure what the slow blinking means.
  15. Mython Contributor
    What charger are you using?
