Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
452 453 454 455 456 457 458 459 460 461
463 464 465 466 467 468 469 470 471 472
  1. rwalkerphl
    Dude, you must live near me - don't you love the south :)
  2. mscott58
    No worries! I do like the 6's, and they're definitely not reference monitor voiced (if that's what technically proficient means), but they are fun. Depends on your tastes of course. And no way I'd trade my K10's away for them. Cheers
    Mython likes this.
  3. AudioBear
    Normally that would be a good bet but in this case my banjo-playing wife lives with me in far Northern Idaho,  You might be able to hear her on quiet nights though.  In all honesty, she's a seriously good amateur player and the noise--uh, cancel that I mean banjo music-- doesn't really bother me.  We jam together with friends all the time.
    One of the reasons I bought the Mojo for my iPhone and 64 Ears A12s was for quiet.  They really exclude noise and I'm hoping Mojo will make the A12s sound even better--if that's even possible.
  4. joshk4
    Has anyone used this with full charge (without charging) and reach the ~10 hours (give or take)?
    I can manage at most 5 - 6 hours on full charge.
  5. koziakauzu
    Same here, maybe 6-7 hours. On my 4th charge and it takes around 5 hours to charge completely.
  6. Nikonkit
    Hi, i am lusting after the Mojo but being an ipod classic user can only affortd to use my LG G3 as a player, is that a vast difference in SQ using a phone against a delicated player like the Fiio or Ibasso
  7. x RELIC x Contributor
    Nope. Not in my opinion anyway. :)
    The source is just a transport and the Mojo does all the heavy lifting, so unless something is seriously wrong with the source's file decoding or the source's digital output the sound should be basically the same from different devices. You may have a hard time with EMF noise from a phone though unless in airplane mode.
  8. joshk4
    I meant it provides up to 10 hours use on full charge.
  9. lukeap69
    I prefer the SQ of my Mojo Jojo/Android phone combo to the Mojo Jojo/FiiO X5 combo.
  10. music4mhell
    Technically there should zero difference in SQ.
  11. sabloke
    Love my Mojo G4 stack. However, there must be a better way to stack'em up than rubber bands... Liusting after a snap on cover that would keep them together and connect the Mojo over USB, something like a Zero Lemon case. Or like one of those monstrous extended batteries that put a hump at the back of the phone but instead of that there would be the Mojo. Need to get my hands on a 3D printer...
  12. salla45
    velcro, i use. there's other sticky-backed stuff you can consider.
  13. lukeap69
    Don't know about that. Android phone is connected by USB cable, FiiO by coax. And they do NOT sound the same.
  14. music4mhell
    That's strange, i wish Rob Watts can explain this difference.
    My query is :
    1. Do you use EQ in any case ? or it's Source out with no modulation ?
    2. Same USB cable used for both connection ?
    3. You listened to same song with same file format in both player ?
    4. Both time you had same color light on power button in Mojo ?
    5. Same headphone/earphone used for both ?
  15. lukeap69
    1. I don't use EQ
    2. Nope, please see my previous post; USB cable for Android phone and coax for FiiO X5.
    3. Yes
    4. Yes
    5. Yes
    Thr main difference, I believe is the input USB vs Coax.
