Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
445 446 447 448 449 450 451 452 453 454
456 457 458 459 460 461 462 463 464 465
  1. x RELIC x Contributor
    Ever listen to the Vmoda m-100? Sounded quite good with the Mojo, lots of bass which is too much for my daily preference compared to the LCD-2. I'd say about +6 dB in comparison.
  2. u2u2
    Hykhleif and Jynxed:
    As a user of both the Shure SE846 and Sony Z5 IEMs I don't think any full size headphone can sound like both as each IEM has a very different sound signature. I was very keen on getting a pair of Audeze LCDs but got seized with indecision as to which model. The strong US dollar put local prices into the stratosphere. Questions dealing with quality control raised on this forum were troubling. I found my solution in a pair of Sennheiser HD800s. Quality, reasonably affordable, and a fine match for the Mojo and my other kit. Might work for your tastes as well. Good luck.
    Sound Eq and jynxed like this.
  3. x RELIC x Contributor
    [@]hykhleif[/@], a couple more suggestions may be the Nighthawks or the Dharma. Sorry for the OT. :)
    Sound Eq likes this.
  4. legcramp
    What cable should I be using to output line out signal to my Audeze's RCA input? Any recommendations? Thanks
  5. bflat
    http://www.amazon.com/Audioquest-3-5mm-Mini-Plug-to-2-RCA-Adapter-Hard/dp/B003VJX2F2/ref=sr_1_2?ie=UTF8&qid=1450055710&sr=8-2&keywords=audioquest+rca+to+3.5
    This plus your choice of RCA cable which you probably have already.
    legcramp likes this.
  6. GreenBow
    Please does it mean that if music music is of 44.1KHz Windows sounds are 44.1KHz, there is no problem? Meaning there is no loss of the first second of manually selected music tracks.
    Does the loss of the first second only occur e.g. when playing HD-audio from a Windows (i.e. 44.1KHz) platform?
  7. boybandista
    From previous posts, Vrms output of the Mojo seems to be at ~5 Vrms.
    But could someone convert it to this?
    • ?mW into 32Ω
    • ?mW into 50Ω
    • ?mW into 300Ω
    • ?mW into 600Ω
    Kinda difficult for me to compare it with other amps with that unit.
    Thanks!
  8. ClieOS Contributor
    You also need to know the output current as well as the distortion to really figure out the power into different load, so it is not a straight forward process that you can convert Vrms to mW.
  9. Hawaiibadboy Contributor
     I get it but the spec sheet is 8ohm to 600 with nothing in between. Since this is touted as a smartphone solution maybe a few #'s like 16 and 32 ohm would be nice. Most companies provide 16 or 32 or both. I get my Mojo tomorrow so I'll see but a 16 or 32 rating provided by the vendor like FiiO, OppO and almost everbody else woulda been nice/expected/S.O.P  IMO
  10. Rob Watts
    Yes 192 kHz is fine with optical - but the optical transmitter needs to be good, and if you use plastic fibre keep the cable short, otherwise you need to use a quality glass fibre cable.
    Coax will actually work up to 384 kHz but it needs to be quality RF coaxial cables.
    Rob
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    onsionsi likes this.
  11. Rob Watts
    If the player does not switch sample rate its fine. But I had this from Matt at Chord last night (he is production director and tests all our digital products with all OS):
    "Of course it only happens when you first play a track or the sample rate changes and only happens if the track has been mastered with no lead in. Some devices fix sample rate so you don't get a problem.
    I don't know if you want to post this as I'm struggling to get this info out via other routes but on J River Media Center you can insert a configurable amount of silence at the beginning of the track in the settings menu. Now for people who prefer to use Foobar you can do the same thing but you need an additional component called affix silence which can be downloaded from this link.
    https://www.foobar2000.org/components/view/foo_dsp_silence
    You then just set the pre or post silence in ms. I tried with 500ms pre silence and 0ms post and it worked well."
    Rob
  12. Hawaiibadboy Contributor
    ________mW @32 ohm
    ________mW @ 16 Ohm
    Roughly.
    I will do a nice comparison tomorrow however since it's a question that is based on spec ...yours...and not subjective experience I would find it quite helpful.
    Thanks in advance.
  13. Currawong Contributor
    The reason is more likely to prevent people plugging devices in which then cause the phone to malfunction, crash, or be compromised. It is not dissimilar to the reasons Chord would discourage people not to experiment with batteries. Sooner or later someone will blame Apple for a problem caused by a device which it was their fault for plugging in. That is why using a CCK with a DAC is completely unofficial too. So Apple is strict about what they'll certify or regard as "official".
  14. NZtechfreak
    Ha, that's a very generous explanation. I don't buy it, not when Android (and heck, for that matter even Symbian) phones have had OTG forever with nobody damaging their devices despite the myriad things that have been tried with them.
    Mython likes this.
  15. Massacare
    I've been using this combo for a while. And to be honest, gonna stay on this one for quite a long time. Mojo is just too awesome for TG!334 :rolleyes:.
    palermo and x RELIC x like this.
