Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
443 444 445 446 447 448 449 450 451 452
454 455 456 457 458 459 460 461 462 463
  1. Currawong Contributor
    If you're after those VanNuys cases, maybe try http://Kuboten.com. The owner lives down the road from me -- I met him through Head-Fi.
  2. koziakauzu
    PM sent
    masterpfa likes this.
  3. jamestux
    Hello again! Your computer treats it as the sound card so yes you can play any audio through it as normal. That foobar issue is and odd one though
  4. Nitrile
    Still having the Foobar issue by the way. Seems to be the case with Spotify too. When getting audio alerts through Windows, half the length of the alert is cut off too. It almost seems like the circuitry on the Mojo takes awhile to kick in after receiving a signal. Or could it be a driver problem?
  5. Hawaiibadboy Contributor
     I just ordered my Mojo. Wanna pit it head to head with my iFi micro and nano. I imagine the power will fall between the 2.
    My question is will most any mini USB to mini usb work? I gotta buy a special one from Yobodashi?
  6. sabloke
    I am using a $4 USB micro to A OTG + cable that came with the Mojo. Works perfectly with my G4. Any USB micro to A works with PCs.
    Oh, you'll love the Mojo base I'm sure. Put some planars on and crank the volume right up. EDM, rap, sludge metal, prog metal, you name it, the Mojo brings those drums alive.
  7. AndrewH13
    Hi there HBB, seen the light :wink:. Can I have your Mojo Rory Gallagher mod? Just joking, before anyone thinks I'm serious. Hope you like it mate.
  8. Hawaiibadboy Contributor
    Been a while since i seen so much praise heaped on an item that is not stupid crazy expensive so I'm going for it. Somebody please tell me I don't need a Moon audio cable for this to work with my Note 4.
  9. NZtechfreak
    Using with Note 4 here, $2 OTG cables work fine.
    Hawaiibadboy likes this.
  10. Hawaiibadboy Contributor
    Thank you bro[​IMG]
  11. Nitrile
    Has anyone contacted Chord about this?
    My primary rig is a Windows PC. :frowning2:
    It happens in any software program, not just Foobar. Tried JRiver too, outputting through ASIO, KS and DirectSound.
    Works absolutely flawlessly on my Macbook (which I use for work) with Audirvana and Spotify.
  12. Rob Watts
    Mojo in common with Hugo has a mute function . This occurs when the usb changes sample rate or switches to dsd. This is to eliminating the huge bangs that some os creates. Losing half a second is better than losing your headphone drivers.... Rob
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    onsionsi likes this.
  13. Sound Eq
    can i connect the mojo to ak100ii via otg usb cable or only optical
  14. Sound Eq
    dont forget to use v4a and get the bass out man, it was such a revalation when i used v4a and mojo
    my steup is
    note 3--- mojo-- shure 846 the bass man the bass was huge, i tried subwoofer in v4a and man what a bass
  15. howdy
    Question,
    So if one where to buy the newest Ipod touch with the newest fw do you still need a cck? I thought I read somewhere in this thread that you don't need one anymore. It would be great to have an Ipod/Mojo streaming Tidal with out all the extra cables.
