Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
438 439 440 441 442 443 444 445 446 447
449 450 451 452 453 454 455 456 457 458
  1. Ike1985
    I have a question about Onkyo, in the equalizer settings you can select HD which uses 64 bit processing. Does this meanj 64 but output in the sense of 16/24/32 or 128/256/320? I notice when I eq a DSD or high quality flac like 24/192, the light on my mojo remains the correct color and doesn't change. I guess that means it's outputting the same quality to and from the mojo?
    Also if anyone has any good pics of what they consider the perfect EQ that gives a bump to 40-60 and 70-90, please share. Eq'ing is complex and I could use the help. I'm looking for increased sub bass and the fuzzy rumble that down tuned electric bass guitars bring, like seen in these two songs:
    http://m.youtube.com/watch?v=l_WJB7KXae8
    http://m.youtube.com/watch?v=pFb607Y49X0
    I only EQ when I listen to rap and doom/sludge metal.
  2. DMinor
    Does anyone know the specific op-amp used in Mojo? Thanks
  3. spook76
    You are right, Onkyo's 64 bit equalizer does not change the sample rate or bit depth of the music. Onkyo will upsample but as I am sure you noticed but that is a separate selection under the settings.
    As for a good equalizer setting to boost the sub bass, I, like you, fear I would do more harm than good so I am sorry I cannot help you there.
  4. Mython Contributor
    I may be incorrect about this, but I don't think the Mojo uses op-amps, as such. Output transistors, yes.
    But other, more tech-savvy head-fiers, may correct me!
  5. heliuscc
    There is an explanation from the designer on this question, it's before page 230, and that's how far I read before I skipped to the end. So it was in the first 230. Someone else may be able to narrow it down, pretty sure opamps weren't the way it's architected.
  6. Mython Contributor
                                          (Click to enlarge)
    Also see: www.head-fi.org/t/784602/chord-mojo-the-official-thread-read-the-third-post-for-updated-info/6720#post_12154576
    DMinor and davidmolliere like this.
  7. Ike1985
    Thanks guys.
    I wa skit listening to Varathron's - Stygian Forces of Scorn, wow guys. The acoustics sound like a live performance, the electric guitars riff up and down the spectrum gloriously, when the drummer plays across his set you can tell where he is and where his hands are, same with the other band members. the blazing fast parts are well understood-every sound is its own sound yet a part of the whole. If I'm going to lose my hearing to this hobby, it'll be to this little black box of joy. I typically start every album on yellow and go up from there, the highest I'll go is light blue for very quiet albums. http://m.youtube.com/watch?v=2HZgAGn4p1M
    Do you guys think I will notice a SQ improvement going form CCK & iphone5 to android since I will only be using one cable instead of 2?
  8. Ike1985
    Nevermind
  9. singleended58
    Do any daps fit in there too?
  10. ade_hall
    Think it means that it can take advantage of the phone's 64 bit processor, i.e. if you have an iPhone 5s or greater. From the Onkyo site:
    Our linear-phase FIR equalizer features selectable HD/SD modes and allows extensive audio adjustment without loss in audio quality. Using a finger on the touchscreen, you can manipulate the frequency response curve into any shape you like, tweaking bass, mid-bass, mid-range, and treble frequencies with precision. In HD mode, a high-precision 64-bit HD equalizer boasts 16,384 bands of FIR equalization to reveal even the subtlest musical nuances in your favorite albums. Memory presets allow you to name and save EQ curves for quick and easy retrieval.
  11. RKML0007
    I am thoroughly impressed with the sound quality and deceptively powerful authority the Mojo exudes when paired with my Alpha Primes. It handily outclasses my DX90>PB2 portable rig in every way. Immediately apparent was the vast improvement with intelligibility for both vocals and instruments. As others have reported, the clarity is phenomenal. For me, the Mojo delivers the goods and substantially upgraded my listening experience to date. I've been happy with a somewhat minimalist approach since joining Head-Fi. But after sampling better sound made possible through Mojo the past few weeks, I knew the time had finally come to venture forth into previously uncharted territory of transportable and desktop goodness that emerged during 2015. Can't wait to hear how well the Ether C's play with Mojo.
  12. sabloke
    I love my metal, especially prog genre, mostly because of its intricate drumming. Mojo takes listening to another level! The detail, the texture of every kick are just fabulous. I'm sure this is how Haake and Pert would like their sound check :)
    spook76 likes this.
  13. x RELIC x Contributor
    No opamp in the signal path. The output is the discrete analogue stage right from the DAC. No seperate 'amp section' like in traditional DAC/amps. :wink:
  14. DMinor
    Could that be the difference made special for Mojo? I think/guess it's about power (consumption of supply & output of power), in addition to low noise/distortion.
  15. Heartsmart
    Code:
    [color=rgb(33, 33, 33)] Does anyone know where I can find a short cable that works between ibasso dx90 and Mojo ?[/color]
