Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12095152
Post #5,521 of 40,385
johndean
I can get the Mojo to work with my iphone 6 plus but not a iphone 6splus i have .
Using camera connection kit and stock cable .Is there a setting in the new 6s plus that im missing?
it just defaults playing through the phone speaker.
post-12095158
Post #5,522 of 40,385
johndean
Well I switched back and fort a few times and got the 6s plus to work.
hmm i hope this doesnt happen when i travel.
post-12095173
Post #5,523 of 40,385
Libertad
quick question can i use this connected to the pc on constant play or will the battery hold it back? Im going to have this by my desktop mostly and i listen for more than 10hrs on some days and id like to know from pc users how it fars thanks in advance.
post-12095333
Post #5,524 of 40,385
Mojo, like Hugo, has been designed so that you can have the charger plugged in constantly. So on a desktop charge and run it at the same time. Once its fully charged, the charger will just supply enough current to balance Mojo's current draw, so no net current from the battery.
Rob
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
Reactions: onsionsi
post-12095344
Post #5,525 of 40,385
lurk
i am considering getting a mojo to 'replace' my hugo due to the substantial size difference
is there a side by side comparison done yet for pro and cons of each unit? I am sure i won't miss the bluetooth feature
been going through last few pages, just too many balls jokes to shift through
post-12095386
Post #5,526 of 40,385
jamato8
To me the Hugo is a little flatter sounding, regarding freq response. There is a little more detail retrieval or a little different way of presenting the detail. They are both excellent, as you have discovered with the Hugo. To me, they do sound different and both in a positive way regarding sound and you have the wonderful form factor of the Mojo.
post-12095390
Post #5,527 of 40,385
glider
Interesting. I don't get any "latent" hiss on Shure SE846s. If there's hiss on the recording it certainly comes through, but I don't hear any otherwise.
post-12095405
Post #5,528 of 40,385
Libertad
My life is complete
post-12095438
Post #5,530 of 40,385
johndean
I don't get any hiss at all with Westone , Nuforce and Sennheiser headphones , iems
post-12095441
Post #5,531 of 40,385
Libertad
so initial charge is 10hrs right before use?
post-12095455
Post #5,532 of 40,385
jamato8
Only if the Mojo hasn't been used for a long time and the battery is very discharged, which new, it is not. It should only require a few hours of charge before the light below the USB on the Mojo goes out. That is all the charge it needs. I just use and charge with a 2 amp and it does fine even when new.
post-12095484
Post #5,534 of 40,385
Dithyrambes
Jebus......Its smaller than I thought it would be.....and sounds pretty freaking amazing ASDJKLFJLKRWJFKLFAJ :)
post-12095490
Post #5,535 of 40,385
jamato8
Have you noticed any change in sound signature with burn in?
I have noticed it is a little more open with burn in. Out of the box though it is fine. I have heard more changes from other electronics. I also think the detail improves some and transparency but again, good out of the box.
Users Who Are Viewing This Thread (Users: 2, Guests: 12)
