Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12094405
Post #5,491 of 40,378
FidelityCastro
post-12094549
Post #5,493 of 40,378
jamestux
Welp. May not be the Mojo (which is a relief).  Plugging it into the computer gives no buzzing.
So.
Is anyone else using a Note 4 as source?  Any buzzing?
Who else is using the eBay-recommended OTG cable?  Any buzzing?
I greatly hope it's the cable, as it's the cheapest and easiest to replace... but I hope I can stick with a $5 cable and not have to jump to a 10x (or more) expensive cable from Moon or other vendors.
Hi, I get occasional interference noises when my S6 edge is near my mojo whether it's the source or not and that doesn't change with different cables
post-12094614
Post #5,494 of 40,378
piercer
I also get interference when it is near my S6 Edge. Apparently putting it into airplane mode helps.
Does anybody know of a portable android storage device with USB OTG but no wireless functionality?
post-12094627
Post #5,495 of 40,378
jamestux
the sony zx2 and zx2? I realise that it's radio interference but putting it in flight mode makes it a pretty useless phone :wink:
post-12094646
Post #5,497 of 40,378
jamestux
Unfortunately ZX2 has a weird connector,
yes it does, I have the ZX100 with that connector and it works brilliantly with the mojo and plays everything I've thrown at it. The other advantage is that it's a great commuter DAP on its own too (with easier to drive phones)
post-12094659
Post #5,498 of 40,378
wirefriend
Sold my Mojo as iBasso DX100 had a bit better tone with 1964 Ears Adel A12 CIEM I usually use.
I think Mojo didn't got enough synergy with it to show its full potential.
I enjoyed Mojo with Denon AH-D5000 but it was not really useful for the portable rig I was looking for.
post-12094681
Post #5,499 of 40,378
johndean
I like the Mojo but upon initial use it does have some treble harshness in the high frequencies .
Hopefully that will settle down as I've only used it a few hours .
I'm using the stock cord ,cck, iPhone 6 Plus
post-12094683
Post #5,500 of 40,378
TomGi
None of those solutions work. I will wait for other people with the same issue to respond. I spoke with another Mojo owner and he reported the same issue.
I use a MBP retina late 2013 with El Capitan.
During playing streaming music or music via J River MC 20, I could hear sometimes some clicks and pops. For my case, it is produced by Safari. Safari closed, there is no problem. If Safari is running, I could have this problem. To me, it is not related to the Mojo. I'm wondering if it is related to the electric supply of the MBP when pop-up windows for advertising purpose are active.
post-12094690
Post #5,501 of 40,378
prismstorm
Hong Kong
Hong Kong
Website
accessibleaudio.co
Thanks for the info @prismstorm
Would you share the start of the serial of your mojo?
FWIW mine has the buzz while charging and serial starts with M023
What is the serial number of your unit?
Without giving away my entire serial,it's M0213XX,so my guess would be from the second batch, no buzzing but tight stiff balls that doesn't roll (I'm not trying to be funny here it just so happens the buttons are in the shape of balls and one would reasonably expect a primary feature of a ball shape object to be rolling, I'm just describing things as they are).
post-12094699
Post #5,502 of 40,378
Gurdipurdi
Received my Mojo last saturday, I liked what I heard but after a week I came to the decision it's not the best match for my Hidition NT6. The sibilance is a tad to much. The NT6's are quite bright, after a week of receiving these somewhere in January I bought the Whiplash Hybrid V3 to tame done treble, this was an overall improvement. (Note: not every NT6 owner had problems with the stock cable, so it might be that I'm more sensitive for this problem.) Yet with the Mojo it's fatiguing to listen to for long times. I must add, I really don't think this has to do with the Mojo. I connected the Mojo to my home rig, which is warm from neutral compared to my CIEM's and the sound was spectacular for such a small package, I had the impressions it came near my Minimax Dac Plus (with Dexa SE op-amps). Just did a quick test with my dad Senn HD-25, and it sounds great, probably the best I heard the HD-25. And then switching to my NT6's everything betters technically, but after a while the doubt rises. I think another aspect is that both components are rather good with retreiving detail, to the point of to much details.
I think it's clear that I'm not blaming either device, just the synergy. And I think that everyone considering the Mojo owes themselves to try and listen. I think that for the majority of phones it's a great match. I will try the X7 next.
post-12094742
Post #5,503 of 40,378
Duncan
Moderator
Compared to what? Guessing you've had a very smooth setup up to now...
Being an honourary member of team treble head, I actually find it I tiny bit muted at the top end, which is the primary reason for me slapping an amp on its back.
post-12094748
Post #5,504 of 40,378
johndean
Slightly muted and slight treble harshness . Of course I use some tube amps from Rogue . In no way is this better than my 2qute.
post-12094752
Post #5,505 of 40,378
Duncan
Moderator
But pretty admirable for a battery powered device at less than half the cost that is "go anywhere" :)
Users Who Are Viewing This Thread (Users: 2, Guests: 11)
