Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
350 351 352 353 354 355 356 357 358 359
361 362 363 364 365 366 367 368 369 370
  1. Tony1110
    That's exactly the combination I use. It's a good little cable. I was all set to get the Moon Audio one until I discovered it.
    salla45 likes this.
  2. mrhizzo
    I can play with the line in/out cable, but it's not the same quality.
  3. salla45
    not sure i understand. U mean rigging  up a combo cable using the coax adapter supplied with the Fiio. Ive done that with my X3ii and its awful. Sounds noisy and completely unusable as a portable solution!
  4. Tom1206
    So what is the best cable solution for FiiO X line? This?
    http://www.custom-cable.co.uk/custom-cable-cc35-3.5mm-coaxial-cable.html
    Or can the coaxial connection work with something like this?
    http://www.amazon.com/L16-Professional-3-5mm-Short-Cable/dp/B00KL7C10O/ref=pd_sim_23_1?ie=UTF8&dpID=416SaG41v2L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1MP41KDXT9MQ9859DA7N
  5. micropixel
    Here's what I diy myself. Right angled connectors definitely works best!
  6. Takeanidea
    Hi Tony,
    I couldn't find a short usb otg on ebay - I ended up making this for £4
    It's not right angled [​IMG] but it'll get me going for the moment
    Tony1110 likes this.
  7. Ike1985
    Been a Jriver user for a year, zero complaints.
  8. Eric510
    Nobody into A+?
    it's working perfectly fine for me... The companion iPhone remote app is a godsend.
  9. reihead
    Impressions after two hours of listening...
    This thing is a beauty, effortless sound
    Doing a NOT so proper comparison with the irDAC, better timing, better soundstage, differences are minimal but clear to spot.
    irDAC is no scrub, but SO glad I decided to give it a go, irDAC is going back to the shop...
    Using it with a BottleHead Crack and HD600
  10. u2u2
    Well said. Works well with all my kit - Sony, Woo Audio, and Chord. Could not be happier.
  11. chronograf86
    I've already reported you to the administrator! Change that nick before someone else will do that for you !
  12. pitchblack
    Does anybody use the Lotoo PAW5000 as simple transport on the Mojo?
    It looks like a good solution because the prices for new or used AK100 Mk2 and AK120 are going through the roof in Switzerland at the moment.
  13. Takeanidea
    First headfier I've blocked. Was very easy whilst we await moderators to step in
  14. salla45
    here's the link again for those who're interested for the short right angled OTG  cable
    http://www.ebay.co.uk/itm/301228419677?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    reihead and Takeanidea like this.
  15. Takeanidea
    Thank you that's very kind to share that -I've ordered 1- £4!
