GreenBow
- Feb 6, 2015
Just to clarify. Charging is automatic. If you are playing and charging at the same time, with a fully charged battery, the charger will supply enough current to balance the consumption used by Mojo, so no net current into the battery. If its fully charged and the unit is off, the charger will go off. The charger will re charge automatically when the battery voltage falls to 8.2v (off at 8.4v) so keeping the charger connected will ensure a full charge.
Rob
Thank you. That's brilliant. Insight into this is helping me make my decision. Really intelligent design without a fault.
This is a link which I think shows the review I mentioned earlier. It's an Amazon UK 1-star review of the Chord Mojo, criticised for the charging status. http://www.amazon.co.uk/product-reviews/B016MXEY5U/ref=cm_cr_dp_hist_one?ie=UTF8&filterBy=addOneStar&showViewpoints=0
(EDIT: I have added your reply about the power and charging circuit to the Amazon 1-star review comment.)
