Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
287 288 289 290 291 292 293 294 295 296
298 299 300 301 302 303 304 305 306 307
  1. all999
    Understood. So You have to admit that You are no 100% sure Your sound card does not affect Your measure results in this particular case.
  2. h1f1add1cted
    Did you see the both results? I can do this 100 times, or use an other sound card, it is always the same result. All my dac/amps under 1 ohms have ruler flat results, only Mojo has slight treble roll off. All is good here, Rob Watts already answered to this "result" shortly: http://www.head-fi.org/t/784602/chord-mojo-the-official-thread-read-the-first-post-for-updated-info/4320#post_12058437
    Again I have no problem with SQ all is good with Mojo... only want to know what exactly causes this nothing more. :wink:
  3. JaZZ Contributor
    I'm not saying it's a bad thing (actually already stated the opposite), but I can't relax before I know what's going on – technically. I'm just highly interested in seeing on paper what I hear with my ears. There are enough people who don't care about techncalities, some even add an amp to Mojo and Hugo thinking it might «improve» the sound [​IMG] (as you may know). Well, in the case of a HF drop-off at low impedances at least this aspect could halfways justify their approach.
    The interesting point would be the impedance curve of the IEM. That's what Miko has asked for.
  4. h1f1add1cted
    You need to ask Piotr from The Custom Art for that...
    Btw. why you don't measure by yourself your IEMs and the Mojo / Hugo ? I don't believe all IEMs will have the same change, I only have currently only one multiple driver IEM, so I can't do more testing on that, since my results showed us with single driver IEMs all keeps flat, always.
  5. NikonGuy
  6. Dionysus
    Can I use the Mojo with the AK JR? thx in advance.
  7. JaZZ Contributor
    Currently I don't have a soundcard – the E-MU 1212 in my old (reserve) computer is dead.
  8. equedadoii
    thanks greenbow.
    and so the moneysink begins!
    the kef x300a is absolutely gorgeous. they're out of my range, but beautiful nonetheless.
    if you end up coming across some convincing reviews or any other setups, make sure to post.
    i'll hunkering down doing more research; i hope to be pretty thrifty with this purchase if i can. :)
    by the way, what would indicate to me that a speaker is indeed self-amplified/powered? the b&w 685 s2 for instance?
  9. Mython Contributor
    AFAIK, the AK Jr does not have a digital-output (someone claimed theirs did, but showed no convincing evidence to support their claim).
    Therefore, if the AK Jr does not have a digital-output, then it cannot be used with the Mojo.
  10. Dionysus
    thank you.
  11. musicheaven
    I drew the exact same conclusion, AK Jr is out of the race.
  12. WCDchee
    The Kef x300a is good for the price, but bear in mind that the analog input is not a true analog input, it goes through an ADC inside and then goes through the internal DAC once more. Thus, you're really wasting any external dac that's being used, as the conversions to and fro within the x300a will limit sound quality to be on the level of the internal dac. So if you're planning to use the mojo with it there are probably better options out there :)
  13. equedadoii
    anything specifically you'd rec? :)
  14. NikonGuy
  15. musicheaven
    You're in the same boat than I am but my choices are quite different and they have evolved over time. At the moment I am considering the following:
    Genelec M030 or M040
    Eve Sc205 and possibly TS107 to TS108 (the sub might be for a near future).
    I gather in you case you want to go with audiophile grade monitors as opposed to studio based.
    Have you had a chance to listen to them at a dealer?
    Angular Mo likes this.
