Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
282 283 284 285 286 287 288 289 290 291
293 294 295 296 297 298 299 300 301 302
  1. sandalaudio
    That is really weird. Has DoP playback ever worked on other DACs, or with another software like Foobar? Have you tried other DSD files, such as the demo tracks from 2L? (http://www.2l.no/hires/)
    As long as all the DSP Studio settings are unticked on JRiver, Mojo should do DoP without any issues.
    It's often a problem with JRiver or Windows configuration, but the fact that your Mojo doesn't do DoP regardless of ASIO, WASAPI or KS is strange. I'm out of ideas.
  2. JaZZ Contributor
    The Westone UM-Pro30 has 56 ohms (at 1 kHz), so typical IEMs with lower impedance will have a drop-off in the range of ~1.8 dB at 20 kHz, unfortunately with a distinctive start above 10 kHz already. Provided that your measurings don't suffer from the same errors that have happened to h1f1add1cted according to John Franks.
  3. sandalaudio
    Yes, well it's just load sensing, so there's no reason to say one kind of amp performs better than the other. Having the output clamped to constant voltage is not necessarily the best solution anyway.
    It's just that unless Chord gives us some insight to how the headphone amp works, I'm sure a lot of people would go frantic that it's not a ruler flat response. I think the same thing happened to Hugo a while ago, and yet nobody's complaining that it's a bad sounding headphone amp...
  4. singleended58
    Yes, it is. Moon Audio is a family business and Drew is a responsible and professional business man. He takes care your order from A to Z with the help of his wife Nichole. The best communication with Drew is calling to follow your order since Mojo is a hot product nowadays. The delay is actually from the manufacture and is absolutely not from the distributor.
  5. mscott58
    http://www.sysconcept.ca/product_info.php?products_id=349
    I'd recommend the 5mm
  6. singleended58
    Nice yellow cover. Where did you get that?
    Would you send me the link of sysconcept cable? Thanks.
  7. equedadoii
    can anyone explain to me how line out works on dac/amps?
    i'm thinking of linking this to a elac b6 speakers someday (i don't believe they're powered, but i could be wrong).
    would the line out function support the b6s or would i need to buy a separate dedicated amp?
    and if so, any recommendations?
  8. mathi8vadhanan
    It came with the AK100. I believe it was bundled with the silver limited edition.
  9. maxedfx
    if you don't mind me asking, where did you pick up the ak100 from??
    It looks awesome!
  10. ksb643
    My previous dac was the Ifi dsd Nano, never needed to use DOP. I'm really stumped. I also have a bunch of dsd iso's and a few in dsf. None of them will display in dsd, they all show 768k. I have 1 DXD album, it shows 192k. 44.1 96k and 192 all play properly. I can't get foobar to work. Will uninstall the Mojo driver tomorrow and reinstall. Thanks for the help!
  11. ksb643
    I don't see event style in the settings. Asio also doesn't work.
  12. mscott58
    Drew's also hell-on-wheels on the kart track. His nickname should be The Terminator as he lives to take people out! Cheers
  13. sandalaudio
    ELAC B6 is not an active speaker, so you should get some kind of amplifier to drive it.
    Either you get an integrated amp and connect the Mojo into the line input like you would a CD player etc, (for that, you should switch the Mojo to fixed line output mode, by holding onto both volume buttons while turning the power on),
    alternatively, you can connect the Mojo to a power amp, and use Mojo's volume control to adjust the volume.
  14. mathi8vadhanan
    I got these from eBay. Seller had it listed for $430. I made the offer (citing the $399 listing for brand new mkII) and he accepted it.
  15. equedadoii
    thanks for that! simple enough to grasp even for a nub. :)
    come across any uber valued integrated amps that would sync well with the mojo and b6?
