mikecheck95
I just found this interview... Maybe I’ll hold off on buying a mojo for now.
https://audiofi.net/2021/03/the-right-chord-at-the-right-time/
Try optical or Coaxial input. If those work then it's most probably Mojo's USB port that's causing the issue and might need to be replaced.Hey all! Happy mojo user here for a while. Today my mojo stopped being recognized by my mac via usb (no updates or anything). Like a previous user the power button light recognizes that its connected but no option to select as output. The same holds true for a few other computers around the house. Any thoughts on a fix? PS it was working last night but today no luck. Tried swapping USB cables ect and restarts ect. No solutions in the "issues" thread or post #3.
Alright, thanks for the recommendation - i purchased an optical out today - luckily my macbook is a 2015 so it should still have built in coaxial - will keep fingers crossed!Try optical or Coaxial input. If those work then it's most probably Mojo's USB port that's causing the issue and might need to be replaced.
I have heard first rumors/rumblings about sightings of a Mojo successor which I consider more than mere speculation and wishful thinking. I really hope they go to USB-C connectors.I'm sort of allergic to Micro USB (weird, I know). Have there been any rumblings, rumors or loose talk about a Mojo with USB-C?
The Topping P50 , as good as it maybe, only provides 5V or 15V !fun tweak : disconnect the internal battery and connect to a Linear Power Supply (like Topping P50).
The result is a more lively & expansive sound. I tried to compare it with the internal battery as well as power bank. Ultimately, the result is subtle, but once I heard the LPS, going back to without sounded relatively dull and compressed.
