Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-15940084
Post #40,606 of 40,697
Kentajalli
London
London
This certainly beats the Poly for BT but is there an equivalent unit offering both BT and lossless streaming like the Poly? I don't care about Roon.
Don't be so quick to dis Poly.
Yes, on paper Poly is only BT4.2 and this gadget is all singing, dancing BT5 with LDAC and all - but knowing Chord, the BT module inside Poly must be of finest quality.
As to answer your question, I can not find anything, ANYthing similar to this device, being so small, portable, rechargable and this cheap - anywhere, let alone having wifi, streaming and be lossless.
I am expecting a sound-quality drop betwreen this device and direct connection to Mojo - by how much - it remains to be seen.
It would be interesting to see the range under LDAC 24/96 for this device, I used to have a Fiio BTR5 that used to manage about a meter or less! best I could get was LDAC 24/48 with about 2 meters of range.
Watch this spot . . .
post-15940279
Post #40,607 of 40,697
Daniel Johnston
Not exactly.
You can find many small DAPs (i.e. Shanling M0) with BT and lossless streaming that will feed the mojo via spdif or even USB, but they will not match the form factor/mojo integration of the poly.
Chord didn't focus on BT audio for Poly. It's SBC only and sounds okay. To be honest, with the DLNA, Airplay, RAAT, and onboard MPD/microSD, I don't see why you'd use BT with poly.
post-15940311
Post #40,608 of 40,697
Kentajalli
London
London
Not exactly.
I can not see any lossless streaming on M0 - you need wifi and M0 does not have any.
Do you know any other small DAPs with wifi and lossless streaming.
Actually of great interest to me, is a purely digital player that I can feed to Mojo, that takes a MicroSD card, no screen, no other outputs, but be remote controllable using BT.
Similar to Poly's media player - that is all I require.
As yet, I am not interested in internet music streaming - I just want to play my own music off a storage.
Thanx
Reactions: henrikgadegaard
post-15940372
Post #40,609 of 40,697
Daniel Johnston
I mentioned the M0 as one of the options over on the poly thread. The Xduoo XT10 comes to mind as well. I have no experience with these, just mentioning options mentioned on the poly thread.
Actually of great interest to me, is a purely digital player that I can feed to Mojo, that takes a MicroSD card, no screen, no other outputs, but be remote controllable using BT. Similar to Poly's media player - that is all I require.
You're describing the poly. :)
Thanx
In all seriousness, there is no "poly equivalent". You can piece various devices together to match the functions provided by poly, but they won't have the same integration and small size. Your best bet to get the poly's functions for cheaper is to buy one off of a disgruntled poly user.
post-15942341
Post #40,610 of 40,697
NoGainToBeHad
Can sound quality degrade as the battery goes through its life cycle? I'm thinking in terms of voltage drop in older batteries affecting playback quality. I recently replaced my battery (not holding charge for more than 2.5 hours) and noticed a change in the playback quality for the better (same IEMs / volume / source music) since the replacement.
I think that's pretty much a given especially for devices that depend on reliable current like an amp. Other than capacity lithium batteries differ from other battery types like alkalines by being able to deliver the spec'd voltage (+/- a certain range) over the vast majority of its life span. The falloff for other battery types occurs earlier in their lifespan. So a set of alkaline batteries might not be able to adequately power a flashlight but would have enough juice to adequately power a remote control. A falloff in voltage for a lithium battery is indicative of impending end of life. For my Nest smart thermometer its 4v lithium battery typically functions at around 3.8 - 3.9 volts and the manufacturer recommends replacing it once it falls below 3.8v.
post-15942377
Post #40,611 of 40,697
Kentajalli
London
London
So by your reasoning the answer to the question raised, is - No, sound quality should not suffer, as the Mojo is powered by a Li ion battery, which I pretty much agree.
Perhaps the effect the @captblaze is describing is akin the effect one gets when filling up their tank, and suddenly the car drives smoother!!
:dt880smile:
post-15948373
Post #40,612 of 40,697
xkonfuzed
Boulder, Colorado
Boulder, Colorado
Hey guys, has anyone had problems with the USB input on their Mojo?
The Data USB input port suddenly stopped working. Power USB port works (and charges device) but doesn't transmit data. I'm currently running through the Optical input, but USB data does not seem to transmit at all, regardless of device.
Any input on this is appreciated. I love the Mojo but its giving me a lot of problems which I don't have the time for.
post-15948381
Post #40,613 of 40,697
Kentajalli
London
London
Have you checked it for any physical damage with a mgnifying glass ? or better still take a picture using your phone an zoom in,
Any damage? anything clogged up inside?
Checked with a different cable?
just trouble shooting.
post-15948393
Post #40,614 of 40,697
xkonfuzed
Boulder, Colorado
Boulder, Colorado
Yes, checked both of those and they're fine. Checked with different cable, devices etc.
I've had the unit for less than a month. I don't think the problem here is damage from the port but rather the internal USB decoder not working.
post-15948396
Post #40,615 of 40,697
CaptainFantastic
W Europe
W Europe
Can you still return it or exchange it? I've had mine for more than a year and it works perfectly. I think you just happened upon a rare faulty unit.
post-15948403
Post #40,616 of 40,697
Kentajalli
London
London
unless a large electricity spike found its way in, it is not likely.
the same chip that handles the USB, handles the other inputs too.
If it is only a month old - contact Chord.
If it is only a month old to you, and somehow you dont have any warranty - I suggest you open the device carefully with the right tools.
Disconnect the battery a leave it for ten minutes.
Reconnect the battery, and close it up - try again.
post-15948855
Post #40,617 of 40,697
Totoxio
Mexico
Mexico
So I just listened on my Windows 10 laptop with the Mojo and 2 Jitterbugs (1 in the unused USB port below, 1 above with the Mojo connected to it) after 2 months of listening on my iPad 4.
And I must say, compared to my iPad 4, the bass is so weak! It's mind boggling how that could happen, but it's clear as day!
The sound is a bit harsher/less controlled in the upper-end of the spectrum as well. Even though my laptop has got a Jitterbug, the iPad still has a lot less EMI/RFI without the Jitterbug, resulting in a bassier and smoother sound.
Can someone recommend me the best USB RF/EMI silencer?
The best USB silencer that I know and use is the Minidsp USBstreamer. It converts USB to optical and then feeds the mojo through the toslink input. Optical connection is galvanic isolated by nature and works up to 24/192 with a short or good quality cable. The bass is as clear as it gets.
Reactions: flyte3333
post-15949007
Post #40,618 of 40,697
miketlse
email support@chordelectronics.co.uk and ask their advice.
Reactions: surfgeorge
post-15949124
Post #40,619 of 40,697
Kentajalli
London
London
I never have had any problem regarding RF noise with my Mojo, mine is connected to my cheap Chinese phone with a DIY cable .
But I have heard people having issues. But assuming all issues with Mojo must be RF noise related, may be hasty.
According to Rob Watts the designer, the USB input does have a galvanic isolator built in, and it is usually bad phones and bad cables that cause any issues - but according to Rob , it only raises the noise floor. I doubt if it makes the bass change character.
To test this, all you need is a computer with optic output to connect to your Mojo.
As been said before, by nature optical input is electrically isolated - try it and see if the issue gets resolved before parting with more money and carry more stuff around with you.
Personally, I believe the difference in performance between your iPad and Mojo, is more personal preferences related than anything else.
Good luck
post-15949370
Post #40,620 of 40,697
jarnopp
Reactions: dakanao
Users Who Are Viewing This Thread (Users: 0, Guests: 21)
