miketlse
- May 8, 2016
On one of the Chord threads, there are posts about a HDMI splitter, which splits the raw HDMI output into HDMI which you can feed to the TV, and the audio signal which you can feed to the Mojo.Hi, appreciate this is a very old post. Wondering if you could still help me. I tried to connect my blu ray player with Chord Mojo using an optical cable. However the blu ray player is still producing sound through the HDMI connection. If I disconnect the HDMI connection from the blu ray player I can't see the blu ray options on the TV. Within the blu ray player settings there is no option to disable HDMI sound. Can you suggest a possible solution. Many thanks!
There are plenty of splitters, in this sort of price range.
https://www.amazon.fr/AmazonBasics-Convertisseur-extracteur-audio-Stereo/dp/B07KRWYN4R
