Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
17 18 19 20 21 22 23 24 25 26
28 29 30 31 32 33 34 35 36 37
  1. Black Dog
    Very useful, thank you!
    Still, no native support for ALAC with the Mojo feels to me like an avoidable omission.
  2. Raika
    Demo both hugo TT and yggy , you will come at the same conclusion .
  3. Hubert H
    That's an awful shame Raika as your knowledge, constructive insights and logic will be sorely missed.
    H.
  4. beemarman
    Had issues with mine as well until I changed my Optical cable to the Sysconcept  one. Now it outputs 24/192 without issues.
    http://www.sysconcept.ca/product_info.php?products_id=349
    speedracer1 likes this.
  5. Raika
    you have to be smart before buying anything in head fi .wait until the hype calm down . open your eyes .
  6. No KNOTsense
    Thanks for the link. I might have to pick up one of those sometime soon.
  7. Hubert H
    Agreed, a reasonably priced optical cable, shipped promptly to the UK and certified to run at 24/192kHz.
    I may try an 8 metre length so that I can keep my 'transport' local.
    H.
  8. x RELIC x Contributor
    Again, this is a DAC/amp, not a source player. The MoJo really doesn't decode any format, that's the job of the source that is sending the MoJo the decoded digital signal and from there it coverts the digital signal to analogue for output to headphones or another amp. It's not a question if the MoJo can support ALAC, it's more a question if your source can support ALAC. I've played many ALAC files from different sources and they all work brilliantly.
  9. NZtechfreak
    ^ This. Can't understand all the consternation about ALAC. Do people think this is a DAP or something?
  10. Deftone
    so could you set it to line level out and then use the headphone out to connect to phono in on a headphone amp (3.5 to 2x RCA male Cable) ??
  11. stevemiddie
    Errrrrrrrrr..............It's a DAC, not a DAP
    spook76 likes this.
  12. JaZZ Contributor
    Yes, you could. But you don't need an external amp – the Mojo is an amp, and a good one at that. Also, an additional amplification stage will just add distortion. It only makes sense for extremely inefficient headphones which the Mojo is unable to drive properly.
    And note that any external amp will use the signal from the Mojo's headphone out, so there's nothing to gain except for gain.
  13. Deftone
    yes i understand, so theres no real output straigt from the dac section only. i would like to used the darkvoice tube amp with it thats why i asked :)
  14. Black Dog
    I think I am finally beginning to see the light!
    Thanks for your explanation.
  15. x RELIC x Contributor
    :beerchug:
    stevemiddie likes this.
