Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-15780876
Post #40,441 of 40,583
Jupiterknight
USA/OH
USA/OH
Ah this is good , so it can be controlled via hiby apps and the output to mojo are digital right?
But can't find one in my country. Is the v1a can do the same? Thanks
Yes, it can be controlled from Android/IOS devices with Hiby Link. Yes, outputs are digital. Two possibilities USB-C or coaxial. Tempotec V1a differs by also having an analog part, dac/amp section, but only one digital out USB-C. Otherwise they are the same size, weight and everything else. V1a is a little more expensive.
Reactions: DBaldock9
post-15782295
Post #40,442 of 40,583
CJG888
Braunschweig
Braunschweig
If you are looking for simple portable transport and can live without streaming, dual sd card slots and mobile app to control it take a look at xDuoo X10T II Turntable. It also has internal EQ.
+1!
Reactions: alekc
post-15787942
Post #40,443 of 40,583
Arpeggione
Sweden
Sweden
You and a friend can listen together if you have the same IEMs or headphones... to a point.
Hey, wait a minute ... Are you saying that the two headphone outputs of the Mojo must or like to see the same load, the same impedance, to work properly with two headphones attached at the same time listening to the same source? Never thought about that. Manual implies nothing in that direction. One 30 Ohm IEM in one output, one 600 Ohm headphone in the other; fine and egal? Perhaps you are just talking about the difference in volume levels that will appear.
post-15787949
Post #40,444 of 40,583
pauldoni
indonesia
indonesia
Lol , that iem will blast our ear if the vol set up for that 600ohm cans :xf_eek:
post-15788437
Post #40,445 of 40,583
gimmeheadroom
Czech Republic
Czech Republic
Website
www.head-fi.org
post-15795913
Post #40,446 of 40,583
icyulkn
Could someone tell me how dts-hd and truehd work with the Chord Mojo in Jriver Player or MPC-BE (or in general)? This would be over optical or USB but I'm using optical at the moment. Am I getting the full bandwidth in PCM over 2 channel? Do I need to switch to USB? Thanks!
post-15795963
Post #40,447 of 40,583
kkrazik2008
USA
USA
It doesn’t work, those are multi-channel audio formats. Your player is down mixing to 2.0
post-15796640
Post #40,448 of 40,583
icyulkn
I'm confused, I read somewhere that you can hear lossless from optical as long as it's PCM and 2.0 channels. Isn't that what Jriver/MPC-BE is doing? Turning the 7.1 to 2 channels according to my software (with JRSS Mixing ON)? I can hear these formats fine in my headphones, what's it playing at?
post-15797408
Post #40,449 of 40,583
kkrazik2008
USA
USA
I have no idea what the software on your end is doing to the PCM file to down mix, all I can tell you is that the Chord Mojo can only output stereo audio. Maybe if the file you are playing has a 2.0 track you could select that to receive the lossless PCM?
post-15797437
Post #40,450 of 40,583
icyulkn
Do you know what software/setup I can use to get the best audio quality from a chord and dts-ma/true hd sound file maybe? How do people normally listen to these formats with their Chords for best quality?
post-15797442
Post #40,451 of 40,583
dontfeedphils
W MI
W MI
Why wouldn't you just use the 2 channel track rather than try to down-mix an Atmos or DTS track?
post-15797667
Post #40,453 of 40,583
dontfeedphils
W MI
W MI
post-15797734
Post #40,454 of 40,583
icyulkn
So AC3 is better than TrueHD in this case? I thought it sounded pretty good with the TrueHD track to be honest with you.
post-15797738
Post #40,455 of 40,583
dontfeedphils
W MI
W MI
Lol, then listen with the TrueHD track.
I'd listen with 2 channel, since you're using a 2 channel device. Then listen to TrueHD when/if you're using an atmos setup. That's just me though.
Users Who Are Viewing This Thread (Users: 1, Guests: 10)
  • Top
