Hello everyone, This is my first post, happy to be here. I'm new to the headphone world. It all started with the smule singing app. I use Sony MDR-ZX700 headphones for recording purposes. After recording i listen to recorded songs via Sennheiser HD599. My phone, Sony xperia xz premium is very pleasant and warm sounding, but struggle's to properly drive sennheiser HD 599 headphones. After reading a few reviews here, i found that chord mojo is very warm sounding and have ample power. Some videos online indicate that there seems to be a big problem with the battery of Mojo. How many years of trouble free experience do u have? your reassurance can really help me decide. Thanks in advance, Regards.
Don't cha get and listen at same time, or rather don't leave charged while listening for extended period of time.my Mojo is 2yrs old, still getting a full 8.5hrs on a full charge, no issue
Make sure to use the current amp charger(1 amp), use the supplier charging lead. Mines is mostly fine after 2 years. More advanced battery life tips are don’t let it totally discharge, just turn it off when you get the red warning I suppose.
With minimal care, at least 3 years. As stated abov, don’t charge and listen at the same time. I replaced my battery after about 3.5 years because I was only getting about 5 hours on a charge (which would likely not have been an issue for my listening), but that was way off from Poly, which was more like 9 hours. Now they are more aligned with playing time.
I read one review how to connect mojo to ps4. Is it right? I don't understand why I need to connect it also to USB? Optical connect and sound working,.why I need to also connect USB? USB+optical connection same time? Why?
No, it’s incorrect, you just connect to optical and then change the setting in PS4 to output to optical.
I still get 7-8 hours of use from my Mojo and I’ve owned it since launch, but I listen to it less now than I did in the first few years. The previous advice is good regarding full discharge and over heating, but also keep in mind that like all lithium battery powered devices don’t plug it in 24/7 and you should be fine with the longevity.
Exactly a USB to SPDIF Bridge can convert USB to coax, AES, or optical spdif. See my reviews of 4 such devices on my blog. Link
But supplier cable is too short for charging. May be cable not play important role in term of charging?
And what about - if I charged mojo on full and trying to listen and charging. It's not working correct? I mean it will lose charge and charging? No difference full charged or half charged, all scenario don't advise to make this way? Yeah?
Wow, this bridges cost too much! Maybe good USB cable will be not worse than usb-->optical bridge? My laptop not have optical output, and I read on head fi that optical connection give mojo best sounds. It's hurts me...
I think different leads can carry different voltages, but I’m just thinking of ways to play it safe if your concerned Chord also replace battery at cost and there are diy videos too.
Not really sure what your problem in finding them might be, but here are the links to the 4 reviews. http://digitalaudiodirections.blogspot.com/2016/03/bryston-buc-1-usb-spdif-converter-review.html http://digitalaudiodirections.blogspot.com/2016/03/yellowtec-puc-2-lite-usbaes-bridge.html http://digitalaudiodirections.blogspot.com/2016/03/mutec-mc-12-bi-directional-usb-digital.html http://digitalaudiodirections.blogspot.com/2016/04/new-best-bridge-in-house.html
This post is indicative of a fair amount of mis-information about the raspberry pi or any other computer for that matter as it relates to computer based audio reproduction. Let's get some facts straight right off the bat. the Raspberry Pi was never meant to be a purpose built computer for audio. It was and always will be a compromised computer built to get computing power for the lowest possible price available to the masses. It has a gimped USB / ethernet shared bus that is terrible for data and as an audio data path to a USB dac. It has problems with cheap and noisy power supplies that must be dealt with by using better multiple power supplies to mitigate overall noise when used in an audio playback environment. It generally runs a Linux OS which limits one to running playback software that may be competent but cannot be regarded as superior to Mac and Windows offerings that provide solid and audiophile playback software. Wait a minute, any Linux software used by the mainstream in creating music,.....I didn't think so. This is not to say that with a lot of work, one cannot make a pi sound good at audio playback, it can be made to sound very good. But to state a Pi's superiority to a Mac or Windows based playback system with superb playback software where those computers are dedicated and tuned to do music playback alone is ludicrous.
