Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-15195521
Post #39,211 of 40,351
iDesign
Has anyone identified a short Apple Lightning to Micro cable that currently works with iOS 13.1? I would prefer to not use the Apple Lightning to USB Camera Adapter cable. I previously purchased aftermarket cables from Aliexpress and Amazon that were mentioned in this thread and they worked well until Apple made software changes.
post-15198709
Post #39,212 of 40,351
cirodts
Every source that I put at mojo il mojo sounds different, which do you think are the best dap-mojo combinations for a better sound?
post-15198749
Post #39,213 of 40,351
surfgeorge
Member of the Trade: 3D Printed Accessory Designer
Austria
Austria
I can recommend the Meenova cable which is small, relatively cheap and works well.
http://www.meenova.com/st/p/lgtnmuc.html
I have both the short and the long version.
The short version has worked reliably, the first long one I received had an issue but Meenova was very helpful in resolving it.
In fact it is working better than the (relatively old) Apple Lightning-USB Adapter I have, which is not always detected.
post-15199947
Post #39,214 of 40,351
Totoxio
Mexico
Mexico
You are right. Mojo is very sensitive to the source when using USB. So, the best transport would be one with optical output, like Astell&Kern AK100II. Sadly, it costs almost the same as the Mojo. I guess there must be other cheaper options with optical output.
post-15199951
Post #39,215 of 40,351
miketlse
There was a portable transport with optical out, that was proving popular on the MScaler thread a few months ago.
post-15199966
Post #39,216 of 40,351
Totoxio
Mexico
Mexico
Thank you. I did quick search, is it the Xduoo x10t ?
EDIT: Wow, I just found the old model Xduoo X10 is only USD 125 on Aliexpress and it has an optical output.
Reactions: masterpfa
post-15200000
Post #39,218 of 40,351
Totoxio
Mexico
Mexico
post-15200005
Post #39,219 of 40,351
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
post-15200010
Post #39,220 of 40,351
miketlse
I think it's a great option for those who don't use Tidal + UAPP
Yes, if ones main use case is play off a sd card, with optical out, and no need for streaming services, then it is difficult to beat at that price.
Reactions: Totoxio
post-15200624
Post #39,221 of 40,351
cirodts
yet I read that the mojo works better in usb and coaxial and not in optics
post-15200662
Post #39,222 of 40,351
flyte3333
Previously known as Em2016
Hi
Can you share which sources you’ve tried?
I found the same as you when I compared optical to different USB sources that were somehow coupled to AC power.
But all battery powered sources I tried sounded same as optical. As long as the UBS source is running only on battery, i.e. no charging at the same time.
Just my own subjective experience though, which may be different.
For USB sources I use microUSB cable with RF filter - Monoprice sell them.
https://www.monoprice.com/product?p_id=5458
post-15200748
Post #39,223 of 40,351
JamieMcC
UK
UK
Hi guys looking for a bit of help I'm a new Mojo owner in the UK trying to find a short USB Type-C to Micro-usb male to male Cable to hook up the Mojo to my phone any suggestions where to find short leads in the UK or Europe?
Sorted now thanks
post-15200779
Post #39,224 of 40,351
miketlse
Two start points for you:
  • post #3 contains a section for cable recommendations, so maybe there is a suitable suggestion there
  • I bought a Forza Audio Works cable - they will terminate cables with several alternative plugs, so you can choose which option you want, however they are moderately expensive (say 50 euros).
  • Most recommendations were for a cheaper cable that cost only a few euros/dollars
See this post for more details
Hope this helps
Reactions: JamieMcC
post-15200959
Post #39,225 of 40,351
Matpar
Torino
Torino
Yes, that's the one. I was tempted myself.
waiting mine in a few days, then will be trying it with my Mojo through coaxial. Let you know :)
Users Who Are Viewing This Thread (Users: 11, Guests: 13)
