Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-15113614
Post #39,046 of 40,444
Totoxio
Mexico
Mexico
which cable do you recommend for the mojo?
I use this USB cable: https://www.amazon.com/Monoprice-3-Feet-Micro-24AWG-Ferrite/dp/B002GH8OCG/ref=sr_1_3?keywords=monoprice+ferrite+micro+usb&qid=1565365650&s=gateway&sr=8-3&th=1
It is well shielded, comes with a ferrite and it's only USD 5.
I can also recommend this OTG: https://www.amazon.com/UGREEN-Adapt...5366032&s=gateway&sprefix=otg,aps,177&sr=8-15
I use an iFi iSilencer3.0 (a little bit better than a jitterbug, in my opinion) between the OTG and the USB cable.
Reactions: almarti
post-15113661
Post #39,047 of 40,444
dakanao
I used to have this cable as well, it's great for the price, and sounds slightly smoother than the stock cable.
Doesn't the iSilencer reclock the signal, thus adding it's own distortion?
post-15113666
Post #39,048 of 40,444
dakanao
You guys must really love a thick sound if you're trying to get the mojo even more full sounding.
To me, the Mojo stock without that gear, with USB, sounds thinner than my laptops onboard sound. More refined with better separation etc, sure, but thinner.
post-15113686
Post #39,049 of 40,444
Totoxio
Mexico
Mexico
The iSilencer has an "active noise cancellation" filter but doesn't reclock the signal.
More information: https://ifi-audio.com/products/isilencer3-0/
Regards.
post-15113741
Post #39,050 of 40,444
Totoxio
Mexico
Mexico
post-15113774
Post #39,051 of 40,444
miketlse
post-15113853
Post #39,053 of 40,444
headfry
I'm getting great results with JB + Curious Hugo Link - I'm sure there are many options
out there, let your ears decide if at all possible.
post-15113859
Post #39,054 of 40,444
dakanao
Regards.
''REBalance® literally rebalances the signal to address the common problem of clicks caused by jitter and distortion in USB signals. Our technology adjusts the signal to get rid of this unwanted noise.''
Anyway, what sonic difference have you found between the Jitterbug and iSilencer?
post-15113909
Post #39,055 of 40,444
Totoxio
Mexico
Mexico
Rebalance is a confusing term. iFi Audio uses a lot of catching words for marketing reasons, I think. In other sites I found that REbalance means DC offset removal (maybe just a capacitor). Other terms they use on some other products are "REgenerate" and "REclock". I think these two should mean the same, since reclocking means also regenerating the signal. But iSilencer doesn't reclock, I'm pretty sure of that.
In the brief time I had the JB, I found that the iSilencer was a little smoother, and more detailed (darker background?) but really just a little. There's an interesiting post with some comparisons here*: https://audiophilestyle.com/forums/topic/30593-group-test-usb-gadgets-aq-jitterbug-uptone-regen-ifi-iusb30-ipurifier-ipurifier2-update-on-p15…/#comments
Note: The second graph shows a comparison between Jitterbug and iPurifier v.1, which is now discontinued. The comments on the iSilencer3.0 are on page 15.
*This is on another forum, I really hope this doesn't represent a problem with the moderators here. In that case, I'm sorry and please feel free to delete or edit this post.
post-15113950
Post #39,056 of 40,444
Deftone
UK
UK
Well that's first for me I've never heard mojo sound thin no matter what its connected to or with and to top it off it's being used with a headphone that's known for its thick meaty sound, HD650.
post-15116019
Post #39,057 of 40,444
ZappaMan
dynamo hum
dynamo hum
Maybe your laptop is eq-Ing the sound - and its adding bass?
post-15116030
Post #39,058 of 40,444
dakanao
I have no DSP's actived with my onboard soundcard. But ofcourse the bass is more distorted, and can appear thicker that way
post-15116377
Post #39,059 of 40,444
adeseaso
Yup, my phone and laptop have more bass than the Mojo too, but it's not a good sound.
But I don't think it's as simple as 'the Mojo is too clean for bass impact', because side by side the Hugo is such a nice upgrade in the bass department with significantly more oomph, despite also having a more extended treble that may work to skew the impression in the other direction.
post-15116426
Post #39,060 of 40,444
dakanao
With the additional shielding gear I've bought, the bass is way more punchy than my laptops soundcard, when it's in the recording.
Reactions: Amsterdam
Users Who Are Viewing This Thread (Users: 2, Guests: 22)
