Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-15038454
Post #38,881 of 40,379
Dexter22
Did you use the iOS Hiby Music app to control the Shanling M0 through Hiby Link?
I couldn't get Hiby Link to work on my iBasso DX220 through Bluetooth with the iPhone.
Hiby link does not work with shanling m0.m0"s OS is not done by hiby so it will never support it. I use it only as a source. But with CAYIN N3 it works.
post-15038523
Post #38,882 of 40,379
masterpfa
I have sold my Oppo Ha-2 and ordered a Mojo :)
I hope I will be able to tell the difference between the two ...
This was the choice I had 3/4 years ago. Plumped for the Mojo and haven't looked back.
Although I had not heard either before buying
post-15038863
Post #38,883 of 40,379
Audiotistic
Omaha
Omaha
I tried searching here and on Google and have had no luck. Does anyone know if the HiBy usb c to 3.5mm coax cable supports otg? I'm using it with my lg v30 and my chord mojo and sound comes out of the phone speakers instead of the mojo.
post-15038927
Post #38,884 of 40,379
Dexter22
In that case ur phone has not recognized the cable as a device.
post-15038937
Post #38,885 of 40,379
Audiotistic
Omaha
Omaha
Any reason why? I have used the mojo up until now with a usb c otg cable plugged into the micro usb included with the mojo and it works just fine.
post-15039850
Post #38,886 of 40,379
Dexter22
Like u had mentioned, if with another usb c cable if it worked, then ur usb port can recognise the devices as DAC, In USB C to coaxial cable, coaxial converter inside the cable should be ideally identified by the phone as a USB DAC. whether something is connected to the other end or not shouldnt matter here. If you hear sound front speaker, that means USB c port has not recognised this cable. Have u tried this cable with any other device?
post-15040737
Post #38,887 of 40,379
Audiotistic
Omaha
Omaha
I bought it specifically for this use, I don't have another device to test it on.
post-15041062
Post #38,889 of 40,379
Audiotistic
Omaha
Omaha
Then I think it's safe to assume it doesn't work.
Wow, you're just full of insight aren't you? You literally just repeated back to me what I had already said and knew.
Anyone else have this issue, or am I the only one?
post-15042003
Post #38,890 of 40,379
Dexter22
I mean the your particular piece of cable u bought doesn't work. Not the idea of having usb - coaxial cable. U can ask them for a replacement.
post-15043046
Post #38,891 of 40,379
betula
U.K.
U.K.
I am selling the third Mojo I owned. Exceptional piece of gear for its price.
Bought my first one just after the first release in 2015.
Now I run a Qutest into a good SS amp and tried Hugo2 too. Mojo lately was my acceptable compromise on the go.
I bought the Empyrean recently which is much more efficient than my previous Audeze headphones. Out of curiosity I tried them from Mojo and honestly, I was very surprised how good they sounded. Not as good as my Qutest/Taurus combo, but honestly, not that far behind. I actually preferred the upper-mid/treble rendition on the Mojo.
No question, the Qutest/Taurus combo sounds superior, but Mojo alone is surprisingly enjoyable. My combo sounds more spacious with better and more impactful bass, more natural sound with higher resolution and detail retrieval overall, but there is something in Mojo's higher frequencies that makes the sound very appealing.
It almost sounds like the Taurus is a hindrance between the Empyrean and the pure Chord sound. (Even though I am swimming in audio bliss atm.)
That's why I bought the TT2.
Mojo got me hooked on Chord sound a few years ago. Enjoyed Hugo2 and Qutest since then and now Mojo made me upgrade to the TT2 and sell my Qutest + amp combo.
Chord indeed does something special.
post-15043857
Post #38,892 of 40,379
adeseaso
The Mojo roll off is awesome, agreed. I rarely like warmer tonality but the Mojo is so sweetly tuned. If I had to describe it in one word it would be 'Lush'.
As I clock in more and more hours with both Mojo and Hugo the benefits of the Hugo are piling up but I still reach for the Mojo daily for a fix of its sweetness.
Listening to Steely Dan - Gaucho via the Mojo and HD600 as I type and it's just great, to think that one can grab this setup at roughly $500 used is pretty impressive.
Reactions: Deftone
post-15048468
Post #38,893 of 40,379
paruchuribros
This cable works 100% to me with the same setup. But I do prefer Shanling L2 cable for the crisp and full sound.
post-15049312
Post #38,894 of 40,379
vonBurg
Spain
Spain
Hey lads, I would like to pair my Mojo with an Airplay device (under 300€/$) but do not want to get the Poly, which is extremely overpriced to me...
So the goal is to stack Mojo+Airplay device and control the music “wirelessly” with my phone or ipad...
any suggestion?? thanks!!
post-15049341
Post #38,895 of 40,379
Alcarinquei
switzerland
switzerland
I have the Hiby cablem usb-c to coax with HTC 10 and it does not work for otg.
Users Who Are Viewing This Thread (Users: 2, Guests: 6)
