Audiotistic
Mojo contains 3 thermal sensors, that switch it off if it gets too hot.
To reduce the temperature, you just need to stand the mojo on its side - that is a lot simpler than fixing a giant cpu cooler to it.
mojo will generate the most heat, if you play music, plus charge the Mojo from a low battery status at the same time.
It's not getting so hot that it shuts off, it just gets warm.
I'm not "fixing a giant cpu cooler to it", I just set it on top. It's not strapped down, nothing is holding it on other than its own weight. I can take it off at any point and it seems to be working wonders to keep it cool while I charge it and listen to it. How is that harder than turning it on its side?
