Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-15011718
Post #38,761 of 40,331
Egoquaero
Hey guys,
one quick noob question.
Is it possible for the Chord Mojo to connect and function properly with a pure amplifier (not an integrated one, by pure I mean an amplifier without the preamp)?
Say I want to connect Chord Mojo to a Rotel RB 1582 MKII to power a pair of Klipsch Forte III loudspeakers. Is it possible to do this without a preamp?
Cheers!
post-15011757
Post #38,762 of 40,331
jarnopp
Hey guys,
Cheers!
Yes, I run Mojo into my Odyssey Stratos all the time. Depending on your setup, you may want a switch (this one has worked very well for me) if the amp s hard to reach for plugging and unplugging of cables. Just watch the volume on Mojo and always start from no or very low volume!
Reactions: Egoquaero
post-15011793
Post #38,763 of 40,331
Egoquaero
Cheers! Great to know :) That means that I could save money and skip on the preamp.
The setup would be Macbook Pro --> Chord Mojo+Poly in Airplay --> Pure amplifier (like the Rotel RB 1582 MKII) --> Speakers (Klipsch Forte III)
The only problem would be that of missing a physical remote control for volume. It'd force me to always have my Macbook nearby and handy to adjust the volume. Is there a trick to overcome this? Mmm.. like a Mojo+Poly remote control?
post-15011825
Post #38,764 of 40,331
jarnopp
That’s the tricky part. I use the Roon volume control, or adjust manually. But TT2 has spoiled me for remote control!
post-15011892
Post #38,765 of 40,331
Egoquaero
Cool, I actually found a way to control my Macbook with my iPhone as a remote control.
Now another question:
Say the Mojo outputs at line level @3v (with the two lights in purplish/blue) and the pure amplifier Rotel 1582 MKII receives this signal from Mojo, what will the amplifier output to the loudspeakers? The maximum level? (assuming that my macbook is at max volume level)
At max volume these Forte III would most probably make the whole building collapse since they're 99db sensitive (and the rotel outputs 200 watts..)
post-15012057
Post #38,766 of 40,331
AC-12
Gone Fishin' till Hugo₃.
You should be able to add any IR remote control to your Mac. I was initially planning to use an Apple remote with my rPi build.
I'm using a IR remote control to control volume on Hugo2 + navigation seamessly on a rPi. Very responsive. I had to setup up though first on a Mac. It should work for Mac (I believe it does as shown on Amazon Q&A). You should be able to map the Mac media keys to any IR remote.
I haven't updated my build yet, but you can get the gist here:
https://www.head-fi.org/threads/yet...alternative-to-2go-poly.905925/#post-15004881
Product needed is a Flirc:
https://flirc.tv/more/flirc-usb
post-15012123
Post #38,767 of 40,331
jarnopp
I think 3v is too much. The specs for the Rotel say 1.9v input sensitivity (rca inputs), so that should be full volume, or 200 watts. You would likely get distortion or damage at 3 volts. So, if you want to use a remote volume (MAC or otherwise) I would set Mojo no higher than 1.9v, which is 4 clicks down from line level.
post-15012677
Post #38,768 of 40,331
greenkiwi
New Zealand
New Zealand
Note that the "line level" is just a pegged level to make things easy.
If I were you, I'd sort out the Mojo volume that was generally the max you'd ever listen to and then use Roon/Mac to dip your audio to the listening level you'd normally listen to.
post-15012911
Post #38,769 of 40,331
Egoquaero
Thank you for your help guys! I forgot to mention one key element... I own a Klipsch subwoofer R-115SW. Is there a way to connect it without the aid of a proper preamp?
post-15013285
Post #38,770 of 40,331
jarnopp
post-15015998
Post #38,771 of 40,331
dakanao
The sound of the headphone out of my laptop, is actually smoother than the Mojo :O. Ofcourse, the Mojo is way more natural and a lot better with the other technicalities, but the sound of my laptop just takes more edges off of the music, that's it's a very liquid sound.
post-15016022
Post #38,772 of 40,331
Deftone
UK
UK
Your laptop will have a much worse digital filter, some people like the sound of the transients blurred and thats why they like the sound of tube amps that do the same thing but i wouldnt agree it makes it more liquid.
post-15016040
Post #38,773 of 40,331
dakanao
I also use 2 Jitterbugs in my laptops unused USB ports sitting closest to the 3.5mm headphone out of my laptop.
Yeah, the transients get more blurred, and so it's softer in the attack. With a headphone like the Beyerdynamic DT 150 + DT 100 velours, cable changed to Mogami 2893 (which makes it sound smoother and more defined than the stock cable, it honestly is like candy to your ears… I will continue to use the Mojo ofcourse, since the sound of the Mojo is just better.
post-15016052
Post #38,774 of 40,331
Deftone
UK
UK
I didnt say it was bad just that it is preference.
post-15016063
Post #38,775 of 40,331
dakanao
I didn't mean liquid in the sense of fluient timing btw, just the sound is as smooth as I've ever heard, yet still with great naturalness and clarity. But that's also a big characteristic of the DT 150 w/ Mogami cable itself.
Such an underrated gem.
Users Who Are Viewing This Thread (Users: 6, Guests: 18)
