Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. ZappaMan
    I think the laugh was meant in a nice way
  2. Vyyy
    I misunderstood... sorry #GreenBow
  3. Vyyy
    Interesting thing this supercap has 5.7V 2.3Amps 5Farads and thats enough for Mojo to operate plugged in. But power input from pc usb 1A is not enough. I suspect it needs at least 2A. My power bank anker has output 5 V / 2.4 A and thats good for supercap continuos charge
  4. GreenBow
    I meant - class. I bet there are a few desktop Mojo users thinking about your idea.
    Mojo TT, ace!
    (It hope it's safe. Remember that Rob told us that the Mojo is not tested to run off charger without battery. I think it should be as Mojo can charge and play at the same time. I think Rob was talking about something else other than safety.)
    I wonder how long it will be before someone tries it with Hugo 2.
  5. Vyyy
    I understand its safe. It works same way as with internal battery (power circuit is th same) - just not the battery for 8hours, but supercap for few seconds. During play it uses supercap power always as with standart battery.
    But boy that dead silent and precize warm play is astonishing:)
  6. GreenBow
    Sorry about my typos in my last post. Have corrected. Am almost fast asleep at my desk right now.
  7. scook94
    @Vyyy How long will Mojo last powered by the supercap?
  8. Vyyy
    With 5 farads - 3-7seconds avarage depending on volume level.
    There is a space for second supercap, but the point that its relatively very short time and i wont invest and its also not so cheap.
    The most important is that its enough power to switch on and let play and charge. And input power is enough to keep it recharged always.
    scook94 likes this.
  9. Caguioa
    How would yall compare this vs the
    Ifi idsd black label?
    On the fence for black label
  10. tacit
    Never heard idsd black label but Mojo sounds better than ifi xDSD - latest portable ifi product.
  11. jarnopp
    So, I just need to say how awesome Mojo is, even after using for 3.5 years primarily with headphones. My TT2, which I bought to drive Omega SAM speakers, as well as headphones, had to be sent for a repair. I’ve been using Mojo with one output driving the Omegas and the other connected to an active sub, and it’s been pretty incredible. The connections are pure Frankenstein, but the sound is still glorious.
    zr0dfx, natch, Vyyy and 5 others like this.
  12. Leo888
    May I ask how is the integration/coherency of the speakers and sub?
  13. jarnopp
    It’s good. The sub (Elac Debut 2.0 3030) has a self-configuring DSP for the room. I select the cutoff for the sub (the Omegas run full range direct from the amp, or Mojo in this case). I also select the bass level. So, I select 60hz for the cutoff and adjusted the level with a spectrum analyzer. The Omegas go down to 40-ish on their own, but the effect on unamplified music is often very subtle. On bass heavy tracks, though, it’s practically required.
    Leo888 and DBaldock9 like this.
  14. Leo888
    Thanks @jarnopp
    That's helpful information which I have not thought of. Have been considering to add a sub but had no sub out on my int amp. This will probably allow me to hunt for a suitable sub.
  15. jarnopp
    There are various connection options, and Ray-Dude has posted about his experiences in other threads with Voxative units, but for max transparency, find one that has connections and controls where you don’t have to use the sub crossover to the main speakers.
