My honest opinion. The A&K 120 is too much money for a file source.
Only if not also being used separately without Mojo when desired.
I find the Coaxial input of Mojo better sounding than USB input.
For the Coaxial I use the old DAP Fiio X5 (first generation) and for USB I use MacBook Pro mid 2012 with Audirvana Plus.
Please describe better for others’ reference. Brighter? Darker? Smoother?
the best as a transport among the tested dap?I find USB and Coax sound identical. Personally like Coax, I have a one inch 75 ohm cable, but even small mono RCA cable does the job and not sure there is a difference using Digital 75ohm at that size. For a tiny Source, Shanling M0 works. Fiio X5, IBASSO DX90, Pionner100 and AK SE200 have all worked well for me.
Edited - deletedI read that the best transport for mojo is easther m1 is it true?
And if you turn down the leds and flip the Mojo over you get lower noise floor.
sorry as m1 you mean Shanling M1 or Soundaware Esther M1I use the M1, and the hibylink app enables me to control the M1 from an android phone, or my ipad - so the small screen size is not an issue.
shanling M1sorry as m1 you mean Shanling M1 or Soundaware Esther M1
Maybe have a look at FAQ's in the third post?Just got a used Mojo. The only USB cable I have to use with it right now is the USB with 2 micros (one for listening and one for charging). I'm thinking about getting a different USB to Micro cable -- are there any you recommend? I feel like the Black Dragon cable looks nice, but I don't really want to spend $80+. Are there any a little less than that you'd recommend?
That looks brilliant. I wish I was that tech savvy.Since it might interest some people in this thread - I posted a simple DIY project for a Mojo-compatible mobile streamer device here (basically same functionality as the Poly, though not as fancy): https://www.head-fi.org/threads/portable-streamer-player-for-chord-mojo-and-others.892968/
