Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. headfry
    No problem here, note that I am using the newer Lightning to USB 3 Camera Adapter,
    I found the original CCK was unreliable - would break after a few months - but the USB 3
    one has lasted me so far more than a year and a half. If you're already using this adapter,
    not sure what the issue is.
  2. bikutoru
    If it happens only with loudspeakers and not headphones, I'd suspect it is your amp and not the Mojo that does something. Of course unless you connect your speakers directly to the Mojo.
  3. Adu
    I don't have issues connecting the Mojo to my iPhone 6S (A1633) with iOS 12.1. DSCN9046.JPG
  4. jwbrent
    I bought my silver cable from Zee’s Music which has the CCK chip built in ... just checked, no problems with iOS12.
    onsionsi likes this.
  5. onsionsi
    If you don't mind can you post the link for this cable?
  6. jwbrent
    Sure!
    Adu likes this.
  7. bobeau
    FWIW, the one I posted earlier today works great and is only $15.
  8. jwbrent
    The Zee’s Music cable is OCC silver plated copper, hence the higher cost.
  9. bobeau
    Which is arguably* useless for a digital cable. It looks cool/well built though.
    * since this isn't the sound science forum
  10. flargosa
    Alright, went to BestBuy bought another lighting to usb camera adapter. Everything works again. Glad it was just a cable issue. You guys use more durable cables to connect your Apple products to your Mojo? This is my third lighting to usb camera adapter. So I have spent $90+ on this cable alone. Expensive.
    canali likes this.
  11. bikutoru
    Tried very old Lightning to USB 2 as well as the newer USB3, no problem on Phone 8 with iOS12
  12. bobeau
    Apple's cables should be fairly durable, it's more about their shifting implementation to determine compliance. I'm into an aftermarket solution primarily for a minimal setup.
  13. Skyyyeman
    I have had absolutely no issues with iOS 12, using the Apple Camera Connection to the Mojo. Perfect from the very first second.
  14. jarnopp
    If you want an iPhone cable this short, are you using airplay mode all the time to avoid RFI, or iPad without cellular?
  15. jwbrent
    No, I stack my Mojo with my iPhone SE, hence my desire for a very short cable. I was always put off by Apple’s CCK because of how long the cable was (plus the need for a second cable/fitting that connected to the CCK’s female USB), so I was glad to find a 12cm silver cable that had embedded in it the CCK chip. Works great, sounds great, especially with lossless files.
