NaiveSound
- Nov 8, 2015
Do you guys enjoy the Poly?
Is it possible for one of the 3.5mm outputs to sound worse than the other, if I put my headphone jack too hard in/out of that output? Or will they still sound the same, even though I have inserted/pulled out the jack a bit hard a few times on 1 jack?
Because I have the feeling that the first 3.5mm output that I usually use (were I sometimes pulled/insterted my headphone cable hard into it) sounds a bit more grainy than the other 3.5mm output which I don't use as much.
But ofcourse, that could totally be placebo, but I'm wondering if there's a factual explanation that these 2 jacks will always sound the same, no matter how much tension is set on one of them.
Yes, I feel like the jack on the right side from below the light bulbs, sounds a bit smoother and more refined.. I'm wondering if there's some damage to the jack straight under the light bulbs, or if it was always there, and became evident in a direct comparison..For me personally , the headphone jack on the Chord side sounds the best, it sounds slightly warmer than the other side but the difference is insubstantial in the grand scheme of things.
But when I’m listening with a friend you already know what side they will be listening on
They can but (assuming it's not complete garbage) the effects tend to be small enough that it won't be noticeable unless you've got much of the other bottlenecks in your system gone. Like I wouldn't use a cheap adapter with an expensive cable. And I wouldn't use an expensive cable with a cheap DAC/Amp/Headphone. Etc.Do headphone adaptors have any real world effect on sq?
http://amzn.eu/8s8sJkVCan anyone recommend an excellent 6.5mm to 3.5mm adaptor? I know furetech make some fancy ones.
Are mojo users finding that with some full size cans like my pm1 for e.g. the use of a 3.5 to 6.5 adaptor has become a must? I found with the oppo's the supplied 3.5 jack would not fit so i had to use an adaptor. Are members having similar experiences with other headphones?
I also noticed that the 3.5mm output jack of the Mojo is very tight, so I have to put quite a bit of force each time if I want the 3.5mm jack from my headphone to fit in the Mojo...No firm click in. The supplied 3.5mm jack from oppo quite simply did not fit mojo's headphone in no matter how you tried.
