There is something in Mojo's battery charging curve that does not convince me.
I charged with Anker 40W 5-ports Turbo USB Power Adapter, Model Number 71AN7105, powering CUA (computerized usb analyzer) AVHzY CT-2 (latest firmware) and stock USB-to-USB-Micro cable.
Mojo discharged to Green battery light indicator by playing various Hi-Res files via JRiver MC 23. Volume level ten clicks below from lowest double-red and RHA-T20i connected. Once green appeared I put Mojo to off and let it rest one hour to let it cool down.
This is the charging plot. Plotting starts at 0.1A and was set to end at 0.1A as well, but that never happened.
That is, I stopped it manually after having seen that the less than 0.15A charging started at 2hrs and 34 min was STILL ongoing at 5hrs and 22 min.
Granted, at that time the white charging light was off but What is that 0.14nn A charging that goes on forever?
Same happened with different USB power sources. BTW.
So are we dealing with some parasitic drain? Where does it come from? Maybe from batteries' own PCB?
First time ever I've seen such a charging plot.
Anyway, with Mojo resting charged, off and unplugged the whole night and in the same testing conditions, in the first afternoon I changed plotting end at 0.150A (i.e. 2 seconds below that would have triggered plotting stop). Plotting start unchanged at 0.1A .
This is the plot. Slightly less than 24minutes to see white light going off. But once again the tester's own display was showing that 0.14xx A .
