cirodts
- Jan 27, 2016
thanks, but do I have to turn it off while charging? can I use a quick smartphone charger?
The micro iDSD doesn't charge if turned off prior to connecting. However, it will use and drain the battery in Normal or Turbo mode. The mojo if fully charged prior to using it and connected to a power source will trickle charge when needed. However, it is not recommended to leave it plugged into power 24/7. Quite a few people have destroyed their battery by doing this.If you use a second cable you can use the Mojo as well as charge it, but it might get uncomfortably hot for you. The device should be safe.
I'll ask iFi to clarify the contradiction about whether the battery is being charged simultaneously, but going by their answers on Amazon the battery seems much better preserved. God forbid the Mojo battery starts going downhill that would brick the whole device and its life is limited by default.
I own them both. The iDSD doesn't charge when connected to a computer if the iDSD is powered off prior to connecting. The mojo charges if both connections are used.Is it considered plugged into power if it's connected to a computer through the listening port? I'd be flabbergasted if it basically cannot be used as a desktop DAC/amp in addition to being portable. You also seem to be misinterpreting that FAQ, what's written there implies more of a trickle than a straight drain as well. Let's see what iFi say about the contradiction.
Cars are designed to travel. Yes you can pretty much do anything in it, possibly you can also live in a car if you want but the main purpose is travelling.Is it considered plugged into power if it's connected to a computer through the listening port? I'd be flabbergasted if it basically cannot be used as a desktop DAC/amp in addition to being portable. You also seem to be misinterpreting that FAQ, what's written there implies more of a trickle than a straight drain as well. Let's see what iFi say about the contradiction. Did you read the Amazon responses at all or am I offending Chord too much for your sensibility?
if I press the volume buttons at the same time the lights become brighter, why?
sorry for me the manual is not out so I ask.
thanksPress again and they dim!
The FAQ in post #3 contains far more information than is in most user manuals.sorry for me the manual is not out so I ask.
