Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-13989983
Post #35,191 of 40,442
miketlse
My Mojo isn't working anymore - it shuts down whenever I try to play. Sometimes it shut down right when the music begin, sometimes after 2-3 minutes. I tried playing from Linux / Win 10 / Mac - same issue.
Disappointing; it is less than 1 year old.
Let's try and eliminate the simplest root causes first:
1 - is your battery near empty? Have you changed your charger recently?
2 - are you trying to charge and listen to your mojo simultaneously, with your mojo in a case, and the ambient room temperature is high.
post-13989996
Post #35,192 of 40,442
Boerd
1. Battery is at full (bright white light)
2. The room is not THAT hot - 18-21 C
3. I tried with the Mojo both connected to the charger or disconnected. Same result.
4. I tried with the Mojo both connected to the PC or not. It still shuts down.
I tried to debug myself - Mojo just shuts down.
post-13990001
Post #35,193 of 40,442
x RELIC x
The West Coast, Canada
Did you have the Mojo plugged in 24/7 previously by chance?
post-13990007
Post #35,194 of 40,442
Boerd
Mostly overnight - to charge it. But - there were periods when for weeks maybe I left it plugin to charge (at the beginning) so - the answer is yes, sometimes / no not everyday. Last few months (2-3 months) I didn't have it plugged in the charger 24/7 - only during the night.
Reactions: x RELIC x
post-13990018
Post #35,195 of 40,442
Boerd
Haa! It started working again after unplugging it and restarting it like 6 times... Weird stuff. Even more weird - the battery is now at RED. Go figure. At least I can listen to my music!
post-13990029
Post #35,197 of 40,442
rbalcom
Lake Jackson, TX
Lake Jackson, TX
A bright white light does not mean the battery is at full charge. It means the battery is charging. The amount of charge is only indicated when the Mojo is on and should be green, blue, yellow, red and flashing red in order from full to I'm going to shutdown cause I got no charge. Also, the amount of charge is indicated when the Mojo is on only. While charging, the white light will go out when the charge circuit stops charging because it is fully charged. A blinking white light indicates that the charging circuit has detected a problem and stopped charging the Mojo.
post-13990035
Post #35,198 of 40,442
rbalcom
Lake Jackson, TX
Lake Jackson, TX
Not for long. RED indicates the battery is 2% to 9% charged. Stop listening and plug it in until the white light goes out.
Reactions: Boerd
post-13990150
Post #35,200 of 40,442
harpo1
You've had the mojo this long and don't know the white light doesn't indicate a full charge? The white light indicates it's charging. The light will go out when fully charged. When not plugged in a fully charged battery is indicated with a blue light. Well 80 to 100% is blue.
post-13990191
Post #35,201 of 40,442
miketlse
Doing exactly that.
From the FAQ in post #3:
rob watts said:
Q .... I am thinking the battery is not holding any charge.
A Try charging overnight with the unit off. The charging circuit looks at the state of the battery before charging. If the battery has a very low voltage, it will trickle charge the battery until it gets to a safe voltage, and then full charge will commence. This trickle charge mode can take several hours, and it is done for safety reasons, and it will appear that the battery is not working as the trickle charge mode takes some time. When in this mode Mojo must be off.
There is also:
'However the mojo battery charging circuitry can go into a protective mode, if the battery has been deeply discharged.
The advice is normally to switch the mojo off, and let the battery very slow recharge.
Reactions: Boerd and Mython
post-13990573
Post #35,202 of 40,442
RiseFall123
Italy
Italy
Hi guys,
I've come across an issue with windows 10 (fall update installed), and the Chord Mojo, which seems to cause Firefox v57 (the default version from their website) to stutter when watching youtube videos.
When Chord Mojo is selected as the default sound device (default settings selected in properties), videos will appear to be choppy and judder. When a different sound device is selected as default in windows, there are no stutters. This can be seen by switching back and forth.
Firefox has been reinstalled and tested in safe mode - still choppy. Chrome and Edge don't show this issue.
Has anybody else come across this?
Update : Switched to optical. No issues.
Did you try on another computer or changing the usb port on yours?
post-13990658
Post #35,203 of 40,442
Redmetal1897
I am using the Mojo hooked up to my laptop (Dell XPS 15) to stream music off of Google Play Music. Would anyone know how to access equalizer settings while doing this? Dell Audio gets disabled at this point
post-13990712
Post #35,204 of 40,442
Trapok
I have a question about pairing a DAP with a DAC/AMP,
If the DAP has already a good dac/amp chips on it, what is the interest to plug a MOJO on it?
may be it is a odd question but i try to understand
Users Who Are Viewing This Thread (Users: 2, Guests: 16)
