Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
Tags:
  1. Wildcatsare1
    If you are looking for something with an open sound for bed use, give the Audeze iSine 20, in ear, open planar headphones a shot. Much more comfortable for pillow jamming :wink:.
    DBaldock9 likes this.
  2. bluenight
    I asked earlier if there was burn in time on mojo and one said 24h and one said god no. But i recently whatched this hugo 2 review and the guy claims in the end of the video that it will get burnt in after playing it for a week. This could probably be aplied to mojo then.
    Then i wonder if he means you have to constantly play it for a week non stop otherwise it will never get burnt in. Or if he means you will burn it in by playing music with it normaly with all the shut downs in between for a accumulated time of a week?
  3. RiseFall123
    It’s what I want to achieve, some experiments when the big cans hp will arrive to me.
  4. MementoMori99
    Like I said in a previous post, I highly recommend a "minimum" 24-hrs. of burn-in time for the Mojo. FYI, I ran it "unattended" for 6-8 hours a day while playing music at medium volume levels until the required time was achieved. Whether you decide to break-in the Mojo for 24-hrs. or 40-50 hrs. is totally up to you.
  5. RiseFall123
    While I cannot find any difference during breakin as headphone amp, I find it changing as dac intonche main chain rig. Cannot say if it’s real or “brain in” but I could swear that is real. Sounding more powerful on the middle lows than in the beginning.
  6. DavidW
    Thinking a bit outside the box... I've been on hold with the Poly waiting for it to stabilize. There is a lot of good work now being done by the early adopters, and while I and others wait, it got me thinking about alternates. What I really want in portability is being able to play music from some onboard memory. This would be especially useful to me when I am outside of a wifi connection or where cellular service is spotty. So here is the alternate: is it possible to connect a lightning splitter with an iPhone external storage device on one end of the splitter and the CCK to the Mojo on the other end? If so, that could meet the requirements for external storage assuming one can control the music with an app on the phone.
    Any thoughts on this? Is it is still an idea that is too rough for execution?
  7. miketlse
    You can already put a SD card in the Poly, and play directly from that. Why would you want to add an external hard drive?
  8. DavidW
    This is in place of the Poly (or at least as a workaround while waiting for the Poly to stabilize).
  9. miketlse
    One alternative is to buy a Shanling M1, and fit a SD card in that. It runs Hibylink app, which can now be controlled by iphones or android phones.
    No need to buy a poly then.
  10. bluenight
    Do you mean 24 hours non stop playing without stops?
    This dude in hugo 2 review talks about burn in time for a week of playing, not sure if he means it will only get burnt in playing music with it non stop for a week or it will burn in also using it normally for a accumulated time of a week with shut downs in between.
    Somewhere in the end of this
  11. MementoMori99
    No, 24-hrs. total play time typically, broken down to 6-8 hrs. per day plus charging time until achievement of number goal. By doing this, break-in will be achieved in 3-4 days.
    bluenight likes this.
  12. DavidW
    I'll look into this. Thanks for the suggestion.
  13. lcdman
    It's on sale at musicteck.com, ending today. I had the same dilemma (waiting for the Poly vs buying a cheap transport) and ended up ordering a Shanling M2 from them, which will arrive tomorrow.
  14. RuiPP
    Did anyone try the Mojo with the new Sennheiser IE 80s? I'd like to know how does it work with a 16 Ω impedance earphones? Any hiss?
    Thanks a lot.
  15. Benz-Fi
    Thank you for your help and suggestion found a case and ordered it over the weekend!
    miketlse likes this.
