Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
222 223 224 225 226 227 228 229 230 231
233 234 235 236 237 238 239 240 241 242
  1. KT66
    Testing mobile windows 8.1 this pm and will post either way
    OK-Guy likes this.
  2. stewboss
    Same experience here. I ordered on Tuesday when the system showed 11 in stock only to receive a similar email 3 days later telling me Chord had let them down. I'm a patient person but it's disappointing customer service all the same.
  3. musicheaven
    It works but you forgot digital impedance matching, an analog cable is not set at 75 ohms so you are trying to fit a round peg in a square hole. It'll be marginal at best. You can make your own or buy an already built one which will give you unneeded cable signal reflection.
  4. derGabe
    I can hardly imagine that this makes an audible difference.
  5. FidelityCastro
    I use to feel that way about earphone cable upgrades. Until I tried it.
  6. musicheaven
    It sure will, it'll cancel out some of the digital input signal which will be in possibly two forms, amplitude reduction and possible phase shift all that translated by the DAC so if you feel you cannot hear the difference then just try an experiment with the two cables and hear the difference.
  7. all999
    My Sys.Concept just arrived! It's perfect:)
    giovvanie likes this.
  8. Black Dog
    Thanks, really tempting!
    Some seriously expensive times ahead with Mojo planned to mate with my Z5C and a shipload of new music to be acquired!
    I am now looking @ Tidal, would that be a viable alternative, anybody?
  9. qafro
    Has anyone tried ibasso dx80 with mojo?
  10. meat01 Contributor
    Has anyone even tried the ibasso DX80?
  11. Wilderbeast
    Does the cable hold the stack together? I.e. is it sturdy enough to keep the AK & Mojo in place?
  12. mscott58
    Nope. The stack should be banded/velcro/etc. together to hold the pieces in place, especially since the Mojo is a bit heavy. The cable is not fragile, but i's also not that strong. Cheers
  13. KT66
    but the sound is perfect, can't fault it!
  14. KT66
    out today, so should hear soon.
  15. proedros
    i thought about it myself [​IMG]
    jmills8 likes this.
