Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. musickid
    has anyone had problems with mojo after using a cck3 cable listening and charging the ios device at the same time?
  2. cyclops214
    If you have Any music purchased from iTunes It will not play Through the Onkyo app It's only good if you have AFLAC Files are greater So don't pay the money If you don't have those High-res music Formats. Personally, I Rip my CDs With the Apple lossless encoder So I have no need For third-party Apps on my iPhone.
  3. episiarch Contributor
    My iTunes purchases, those that are not just in the cloud but downloaded/local on the iPhone, do play via the Onkyo app.
  4. cyclops214
    I tried It Last year And it would not work for me Only Music that I ripped myself Would play And not anything by through iTunes.
  5. cyclops214
    I just reinstalled the Onkyo App And I still get the Same problem All music Purchased through iTunes It tells me it is DRM protected And will not play And all my music Is downloaded Directly to my phone. So I would like to know how you are getting it to play On yours?
    Update
    Apparently iTunes plus Doesn't have DRM free Versions of most of my music That I purchased through them Which really sucks.
  6. episiarch Contributor
    That does suck. The stuff I've bought is available DRM-free on iTunes. I'm sorry to hear your purchases are unavailable that way.
    cardeli22 likes this.
  7. musickid
    the anker power port 5 has been recommended for mojo however it talks about fast charging technology power iq and voltage boost and i remember you saying rob advised against such things, the anker power port 5 did come tops in headfi test so im confused here.
    Hooster likes this.
  8. Domdom
    I use Anker to charge Mojo, so far no issue. Anker not very fast but fine.
  9. musickid
    is that power port 5 domdom and how long have you been using it? i have the 1.8m ankerpowerline but chord say no more than 1.5m. awaiting demo of ether flows mr speakers very excited.
  10. Domdom
    It seems to be the 5 ports from Amazon.FR in Jan 2015, but no longer available, 6 ports is. True I use a short USB cable but a standard length should do. Surprised this generates so much debate :) Slow charge is better even if a bit of a pain waiting, Just dont wait for Mojo to be empty? just a thought.
  11. musickid
    have you had any problem with anker power port 5? it is still on amazon.fr apologies for repeating myself its just that rob advised against quick charging technology.
    is there any advantage to using a batterybank 12000mah for mojo over mains charging/power for use at home. better sq, less interference etc?
  12. Domdom
    I have always read slow charging is better for the long run but remember, i believe it is the equipment absorbing power not power supply pushing. As an example: iPhone 6 (or 6S) can charge faster if given power through 10W iPad charger.
    so i you can tolerate slower through 5portz ANKER go for it. Sometimes a little boost may be enjoyable!
    as an other example iPad Pro would benefit from 29W USB C charger but Apple didn't consider adding it to the box, just the 12W :frowning2: and charge is really slow!!
  13. musickid
    what about battery banks like 12000mah must be cleaner or not so?
  14. Domdom
    Can I make a friendly comment / tease. Lets stop being nerds for a sec and listen to good music
    Hooster and cardeli22 like this.
  15. musickid
    you are right my friend. i am taking delivery of £1700 mr speakers headphone ether flow and mojo today. i want to make sure all is good as i had some bad luck before.
