Mojo ideas
Member of the Trade: Chord Electronics
- Oct 20, 2015
Mojo does not play 176 & 192 kHz Material via Toslink from AK240. Equal or less than 96 kHz are no problem. LG G4 OTG with 176 & 192 kHz no problem on the Mojo.
Btw the AK240 plays everything till 192 kHz with Toslink on the iFi iDAC micro without an issue.
Only difference between the iFi and Mojo connection is the optical cable (I don't have yet a short Mini-Optical to Toslink cable).
The stuck buttons are gone after moving the balls a little bit.
send with LG G4
It should certainly play 176 and 192 kHz are you using a glass or plastic cable if so the plastic cable should be short and firmly clicked into the Mojo's receiver. John F
