Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-11995623
Post #287 of 40,445
sheldaze
USA
USA
What is a tap? Is it an abbreviation for something, which I can go research myself?
post-11995657
Post #289 of 40,445
proedros
Athens , Greece
Athens , Greece
I think there are 2 ways both from WM port in Zx2
1/ USB for digital connection
2/ WM pure line-out for pure analog.....uhm...except that Mojo has no analog in...so there is only 1 option.
so it connects with zx2 through a typical usb ?
post-11995664
Post #290 of 40,445
georgelai57
Brimar has not yet tested with Chord Mojo. I was just chatting with them the last hour or so.
post-11995688
Post #291 of 40,445
deuter
I believe the Sony cable should be sufficient, I know it's big but one can always wrap it around the players.
post-11995699
Post #292 of 40,445
proedros
Athens , Greece
Athens , Greece
you mean the stock USB/LOcable that comes with the zx2 and which is used for charging the device ?
post-11995722
Post #294 of 40,445
episiarch
London and California, mainly
It's an element of the type of filter used for reconstructing the waveform from the digital samples.  https://en.wikipedia.org/wiki/Finite_impulse_response is a good starting point.
Reactions: sheldaze
post-11995728
Post #295 of 40,445
JohnStamin
wmc-nwh10
Support Walkman ZX100 To Chord Mojo ?
Features
  1. Exclusive Walkman® conversion cable for Hi-Res Audio digital output *While connecting the Walkman® with other audio devices, the Walkman® unit is not charged
  2. Hi-Res Audio output with Walkman® digital connection to other audio devices: UDA-1, SRS-X9, MAP-S1 (as of April 19, 2014)
  3. Aluminum tape shield reduces the influence of the exterior noise and signal interference
  4. Silver plating processing allows transmission of high-speed digital signal faithfully to deliver high-quality sound
post-11995732
Post #296 of 40,445
mjdutton
  I'm reading these posts with mixed emotions - pleased to read all the positive posts, and I do want a mojo, but only bought my Hugo a month ago.  From experience with Hugo and Hugo TT, what kind of run-in changes can we expect from the Mojo?  The comments so far are based on equipment that has only been running for up tot 20 hours.
You will find the Mojo quite a bit better (musically) than the Hugo.  Warmer, less clinical and better bottom end, and if the first 24 hours are anything to go by it will get better.  I'm hoping that Chord will provide an upgrade for my Hugo, should only be a PCB swap?
post-11995747
Post #298 of 40,445
Duncan
Moderator
Skipping a couple of pages (understandably busy thread!) for those enquiring about the volume control, it is split in two halves, ranging from brown to white on the LEFT button only for 0-50% and then brown to white on BOTH buttons for 51-100%...
Hope this helps
post-11995752
Post #299 of 40,445
Duncan
Moderator
wmc-nwh10
Features
Correct, that's the one :) battery life on the Walkman takes a massive hit though :frowning2:
post-11995753
Post #300 of 40,445
bigjim
Why oh why don't they include a Micro to Micro USB OTG cable in the box, that is an oversight that should be addressed. Its tricky enough to get hold of super short otg's (Hats off to ibasso who's Mini to Micro cable in the D Zero Mk2 is fantastic) without the manufacturers brandishing compatibility with android and then leaving these basics out the box.
Users Who Are Viewing This Thread (Users: 12, Guests: 9)
