Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. almarti
    I will test and consider.
  2. almarti
    Excellent consultancy, I appreciate it. Now I need to find a store in Barcelona letting me listen and compare. I will monitor closely against HD600 if price gap is worth
  3. Light - Man
    Is anyone using the new Focal Listen closed headphone with or without the Mojo and if so how does it pair and what do you think of it?
  4. miketlse
    it is online, and not in barcelona, but it is a competitive price https://zococity.es/focal-elear
  5. TG04
    could i please share in this info?  i'd like to know what my options are ....
  6. tunes
    John Franks (Chord owner) has said the Hugo 2 will get its own Poly-like module for streaming remote content. (Maybe the ""Roly"?)
    Will the Roly have an SD card with at least 200Gigs to store my music library flac files and stream TIDAL DIRECTLY or via Bluetooth from the iPhone that controls the Roly? I guess I'm confused about using the Roly as if the HUGO is now a dap but still needs a UI with the phone??!
  7. jarnopp
    Well, for starters, I made up the name "Roly" to go with the Poly, and there has not been enough detail released about Poly, let alone the Hugo module, but for speculation and some "light reading" I would direct you to the Poly thread: http://www.head-fi.org/t/831347/chord-electronics-poly-advanced-wireless-microsd-module-for-mojo-specs-in-1st-post
    :):beerchug:
  8. god-bluff
    If the Listen sounds anything like the Spirit Classic then with Mojo it will sound sensational.
    My personal somewhat modest 'end game' pairing. Right up to the point when my (3rd pair) Focal's headband started cracking. The Mojo was promptly sold. My (broken) heart was no longer in it:disappointed_relieved:
  9. GRUMPYOLDGUY
    This is just not a good road to go down. Trust me, I know first hand.
    Deftone and warrior1975 like this.
  10. jwbrent
    Wise advice.
  11. Music Alchemist
    About preamp volume with extreme EQ settings...
    I confirmed that the Mojo is like pretty much anything else: if you boost or cut frequencies by extreme amounts, it can distort, but if you reduce the volume in your player (or whatever else) by the level of your highest boost or cut and increase the volume of the Mojo, everything sounds fine.
  12. Rob Watts
    Optical will support DSD with DoP on the optical - but only DSD64. Also, if you use a plastic fibre, only use very short lengths - for longer lengths you need a quality glass fibre. Running optical at 192 kHz is close to the edge for some optical transmitters and cables.
    Rob
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
  13. Bulbsofpassion
    Re Optical cables, I can't speak for DSD but this 1m cable is £6 in the UK and works perfectly at 192khz on my 2015 Macbook Pro:
    https://www.amazon.co.uk/Fisual-Pearl-Mini-Toslink-Optical-Special/dp/B00856P9BQ/
  14. sandalaudio
    As mentioned on Rob's post, 192 kHz pushes the limit of the original TOSLINK optical S/PDIF standard, so too does the DSD DoP (which needs 176.4 kHz).
    In many DACs over the years (not limited to but including Mojo), I had a lot of issues with bad optical (and coax) cables that were fine for 44.1 kHz but had intermittent popping noises on 88.2 kHz+ playback.
    In the end I bought the cheapest Audioquest one (green one, about $50?) not because it makes music sound better or anything, but at least it was super reliable (no pops) and very thin so it's easy to work with.
    Some of the nasty cheap optical cables might look fancy with chunky fat braided sheath etc (they even have gold plated TOSLINK connectors... [​IMG]) but they let me down in countless occasions.
    Aside from the actual fibre/plastic cable quality, there is quite a big difference between each cable brand in terms of how the end of the fibre is terminated (where the light goes in and out). Some cables have the fibre just cut by a sharp knife, some are ground down by a grinding saw (very rough surface), some have a flat piece of mineral glass stuck on it, others have a convex lens glass instead.
    I can't say which method is better technically, but the important thing is that the cheap ones often have a very rough tip finish and I measured very large attenuation (like 30% worse) because of the scattering. Even the expensive ones can get damaged or deteriorated very easily by accidentally touching and scuffing the tip if you carry the cable around frequently without the end-caps on.
    FYI I've posted some photos of the fibre end a couple of years ago.
    http://www.head-fi.org/t/784602/chord-mojo-dac-amp-faq-in-3rd-post/2250#post_12023147
    If the signal is deteriorated so much then I'm sure the Mojo's S/PDIF receiver PLL must work extra hard, so that might affect the sound quality, but I haven't really noticed any subjective difference myself.
  15. GRUMPYOLDGUY
    This isn't a problem with the DAC. Your EQ settings are causing overflow on the numeric data. When you back off the gain universally, the gain in the EQ no longer causes overflow.
