Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
171 172 173 174 175 176 177 178 179 180
182 183 184 185 186 187 188 189 190 191
  1. subguy812
    God forbid you ever sleep...when you wake this thread is like 5-6 pages past where you dozed off.
  2. Mojo ideas
    No the batteries are expected to last far longer than three years. The batteries in our designs are not subject to damaging deep discharge cycles or anything more than very light current demand .... Batteries used for power tools are quite a different matter, but in our units expect a life of greater than ten years. Mojo has a plug on it so it's just an easy replacement for a shop technician Hugo batteries will need soldering in place though but this is also a low skilled job which would be require rarely if ever.
    John Franks.
    MacedonianHero, fluidz and gnomen like this.
  3. OK-Guy
    I stand corrected... be assured that I'll be having words with my info-guy... [​IMG]
  4. elnero
    Is there any harm in most of the time leaving the Mojo hooked up to computer and plugged in to the wall to keep a full charge?
  5. Takeanidea
    the question is will you sleep the night before your Mojo is due to arrive?
  6. sonickarma
    Yawn Yawn, twiddling thumbs - what to do - Hmmm I have an idea
    You know what comes next .............
  7. sonickarma
    [​IMG] - AK240SS>MOJO>K10U
  8. OK-Guy
    voided warranty ?
  9. sonickarma
    Yes ! Took one for the team - so I could share the internals with my headfi associates [​IMG]
    emrelights1973 likes this.
  10. audionewbi
    Doesn't specify on mojo :D
  11. subguy812
    As much as I like Headfi not sure I could've done that even if I had my Mojo yet.
  12. Mojo ideas
    No it's fine to leave it plugged in all the time but if your charging from an unplugged lap top you may drain the lap tops batteries. But if your using just the data USB connection ithe mojo takes no power from the connected device. John F.
    gnomen likes this.
  13. subguy812
    I probably wont sleep..no.
