Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
159 160 161 162 163 164 165 166 167 168
170 171 172 173 174 175 176 177 178 179
  1. stevemiddie
    No heat issues when plugged into my Dell XPS 13
  2. emrelights1973
    thanks, i got my zx2+z7 from Turkey to 1200usd as a promo price.....  must be best price ( still is actually ) in the world... tnx for the cable update, still waiting a custom cable :)
    OK-Guy likes this.
  3. OK-Guy
    think I paid about $900 approx. which included Courier delivery, the leather-case and obligatory screen-protector.
  4. Mojo ideas
    John F from Chord here. We are looking into this for you. Hopefully one of the guys at JH will come back to me shortly. In the mean time we've tested with some Noble K 10s,UE studios and the Dita ranges and all appear to be totally silent at any volume level on both optical and coaxial inputs. Please can you let me know we're you charging your Mojo at the same time. I'm wondering if it's something external in the very local environment and that perhaps you might like to do a little elimination to help us track down the problem as we are not seeing (hearing it our selves)
    OK-Guy likes this.
  5. gndixon
    I wasn't charging my Mojo at the same time -- I did try charging to see if that made a difference, but it did not - the noise is still there. Its the same noise I hear when I switch the Mojo on and hold the case up to my ear with no USB inputs. Should the Mojo be silent when its powered on (the Hugo is)?
    I've tried the Mojo away from any other electronic devices and still hear the noise, so I don't think its interference.
  6. beemarman
    No issue using my Jh Roxanne custom with my old Ak100 connected optically mad the mojo.
  7. Mojo ideas
    JF okay if you can get to a dealer and try another unit ask the dealer to get the suspect unit back to us at Chord with a note and we will give It a very thorough going over... It's very illuminating that you can hear the same sound from the outside of the case it sounds to me that you have an internal regulator problem unit with that unit. We have shipped many thousands of units already so it's possible at this early stage to have an odd faulty unit.
  8. gndixon
    Will do and thanks for the prompt response.
    Fortunately my dealer (Moon Audio) is local (well 45 mins away) so I can drop it off with them. I did email Drew/Nichole and asked if they had heard or seen similar problems (as I know Drew was using a Mojo with JH16 Pros)...
  9. potkettleblack
    Cheers Steve. Do you leave it for long periods?
  10. jmills8
    Has anyone put the Mojo in their jean pocket and do the buttons gets presses accidently?
  11. leasedeb
    why is there so much hype, is this the only portable dac/amp that can be called good or what ?
  12. OK-Guy
    happy customers don't 'hype'... they proudly talk about their purchase, hth.
  13. Mojo ideas
    JF Mojos multiple DSP cores and all other circuitry develop 1.7 Watts of heat when running this heat it dissipated from Mojos case through convection and heat radiating away. This can only happen when the Mojo cases temperature is a few degrees above the ambient temperature so it will feel warm in a high ambient environment. This is normal and totally safe as there are three separate and independent thermal sensing and protection circuits to look after Mojo and Mojos special battery.
    Currawong and potkettleblack like this.
  14. singleended58
    Did anyone receive shipping confirmation of your Mojo today? Second batch is available on 10/27/15 from Moon Audio.
  15. stevemiddie
    Hi..........Nahhhhhhh, usually just 2-3 hours at a time before I get dragged away to do other stuff.
    potkettleblack likes this.
