Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. PLUSSOUND
    We haven't developed mono right angle plugs, but we are able to apply our 3.5mm TRS right angle plugs onto cables for coaxial.
    PlusSound Stay updated on PlusSound at their sponsor page on Head-Fi.
    https://www.facebook.com/plusSound/ https://twitter.com/plussoundaudio http://plussoundaudio.com/
  2. EagleWings
    Could you please tell us which cable one ought to choose for coaxial, as I couldn't find any coaxial cable on your site?
    Thanks.
  3. NaiveSound
    I like a semi permanent sturdy way like hit glue, it'd how I kept it dx80 to mojo attached, I'll have to modify a case, I'll figure something out and post pics here
  4. PLUSSOUND
    Of course.
    1. Visit our Interconnect cable page at http://www.plussoundaudio.com/customcables/interconnect.html
    2. Pick out preferred cable and begin to select overall cable length, wire, braid, etc.
    3. Under connector [1] and connector [2] options, select on both either 'plusSound Cryo Treated Gold Plated Right Angle' or 'plusSound Cryo Treated Gold Plated Straight'.
    4. At checkout, leave note under instructions to seller with anything like 'DX50/90 to Mojo Coax' or 'Coax' or 'Mono to Mono'. If you miss it or forget to add message, don't worry. You can always email us with your request before/after placing the order.
    EagleWings likes this.
  5. EagleWings
    Thanks. That is great news.
  6. Zojokkeli
    Would you prefer.. erm.. flashing? [​IMG]
    Light - Man likes this.
  7. analogmusic
    Nice to get some clarity on this, as some companies in the hi-fi business have been preaching "source first" for decades now.
    Source first never really made sense to me.... but the weakest link does make sense !
  8. Sound Eq
    i got the dyson audio coaxial cable few 2 ago, when I heard what the combo offers I immediately sold my cowon plenue s
    bare in mind I had also in the past ak380 and amp, chord hugo, ak100ii and other items
    best sound I heard till this date is fiio x7 and mojo with dyson coaxial cable
    jmills8 and tomwoo like this.
  9. SearchOfSub
    Listening to my native country songs right now through youtube and it sounds very good. I have DFR to compare here and it seems Mojo acccels overs DFR in low quality files. Almost unlistenable through DFR becomes very enjoyable through Mojo. Very nice!
  10. Mercilesslord
    How do i stream spotify using samsung s7edge with the mojo? Can someone enlighten me? thank you!!!!
  11. gikigill
    Just connect it to the Mojo using a USB OTG cable.
  12. Mercilesslord
    So its just plug and play? Do i need to download any external apps on my s7e like USB Audio pro? And any usb otg cable to recommend? Thanks alot mate for ur kind replies!!
  13. quodjo105
    hi you can just plug and play but unfortunately you're not going to benefit much as it'll still play through android that means the android system will upsample and not feed the mojo with bit perfect signal . You can't stream Spotify using UAPP but you can with tidal . With UAPP you are able to play directly to the mojo as the app uses it's own USB drivers and not through android .
    Ancipital likes this.
  14. White Lotus
    No external apps required, it will work instantly.
    (Did for me, with an S7Edge).
    Unfortunately the Mojo refuses to talk to my Note 7, unfortunately. Weird, as it was so happy to talk to the S7 Edge, and they are fairly similar phones.
  15. HiFiChris Contributor
    tomwoo likes this.
