Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. howdy
    I'll speak for myself when I say that Tidal with my iPod touch/Mojo into my Alclair CIEMs is absolute bliss!!!! No issues whatsoever.
  2. kinetic758
    From reading a few pages back, it appears the issue is with offline Tidal files not working due to encryption issues. This, unfortunately, is a deal breaker for me since my music would strictly be offline files from Tidal (streaming would not be ideal since I'd be using this setup at work) .
  3. EagleWings
    Fair. But might I also suggest an alternative before you give up on the Mojo. You could get an iPod touch which takes care of the EMI/RF issues. And for the Apple Camera Adapter, apple stores offer 14-Day return policy and few stores offer 30-Day return policy. So even if the first unit doesn't work, highly likely the second unit might. You don't have to take this advise. But I thought I should let you know that there are options.
  4. kinetic758
    Thanks. I've also considered this. I don't want to give up on the Mojo as well! Unfortunately, I think what I'm asking for is technically impossible: using offline Tidal/Spotify music with an external DAC.
  5. howdy
    All I'm using is offline to, that's the only way I listen to Tidal.
  6. EagleWings
    Let me explain. Android devices do not output bit-perfect signal through USB out. So android owners who use Tidal, use an app called UAPP to stream Tidal music so that it can output bit-perfect signal. Now Tidal does not allow allow other apps/clients to access its Tidal-Offline tracks. As long as you are using the Tidal app itself to play Tidal-Offline files, you should be fine.
    iOS outputs bit-perfect signal. So you can just use the Tidal app to stream and play Tidal-Offline files.
  7. kinetic758
    Sorry for my ingnorance. So to clarify, the only way to get bit perfect data passed to the Mojo for OFFLINE Tidal songs is with an iOS device, correct? And this would also apply to Spotify offline?
  8. EagleWings
    To the extent of my knowledge, Yes.
  9. kinetic758
    Thanks. Looks like an iPod may be in my future. What a rabbit hole... all I wanted was to use some higher impedance earphones and now I need to walk into an Apple store first?!
  10. EagleWings
    Lol..
    Mython likes this.
  11. appabahn
    I use Spotify with IPhone 6+ and the USB3 camera connector with Mojo and have no problems. The added lightning receptical in the connector allowing charging while outputting audio works great. The only sounds not related to the music are an occasional slightly lowering of volume when I think, email is being received, need to varify that, and a very low level, sort of oscillating, almost mechanical tone, that repeats intermittently while charging with no music playing, and is not audible during play.
  12. kinetic758
    Here's my game plan: my wife is the only iPhone user, so I buy her a new one with the condition that I can use her old one as a source. We then go to Barney's.. I buy her a pair of shoes, with the condition that I can buy this $600 black box that looks like something my kid would have in his room. Let do this.
    cbl117 and GreenBow like this.
  13. jmills8
    Looking at the big picture, she will lose respect for you if you think that way. Do what leading men do in action movies.
  14. kinetic758
    Ha. Well there is a high-fi shop nearby that has the Mojo in hand. Perhaps we can all storm in there (stroller with child in hand) and just buy the damn thing.
  15. artheo
    I 've recently purchased a Chord Mojo upgrading from a Fiio E18.
    I totally agree in everything you wrote, congratulations!
