Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12772246
Post #20,896 of 40,447
rkt31
like one need two ears only to get directional cues in real life situations, you only need stereo to produce all kind of directional cues. problem is to get correct setup for recordings. for headphone listening the effect is replicated by binaural recordings. but binaural set up has its own limitations. for normal stereo recording it is very difficult to replicate the effect as it demands considerable experimentation with placement of mic. there is a chesky stereo recordings ( not binaural) which creates behind your head sound with two speakers only. it was recorded with a single stereo mic. with properly set up speakers ( correct toe in) the behind you sound is reproduced correctly. modern recordings need lot more mixing of different sounds specially in movies so the effect is generated in processing rather actually recording for obvious practical problems. if someone is not concerned about the quality of recordings , some hand held portable recorders create that much wider recording of live events. few days back I recorded my Hugo+ benchmark ahb2+ kef r300 system sound with Olympus ls100 handheld recorder in 24bit 96khz and in between my kids were knocking on the side door. when I listen to that recording it sounds as if there is really a sound coming from extreme right from out side of the headphone. so it is possible to record and reproduce such sounds with stereo setup .
post-12772347
Post #20,897 of 40,447
rkt31
foobar android version has any plugin for bit perfect output like uapp ? I think foobar should end the monopoly of uapp like in windows it's free.
post-12772534
Post #20,898 of 40,447
Mojo ideas
Member of the Trade: Chord Electronics
Th
FURUTECH F35G
High quality gold strike plating that is incredibly scratch and wear resistant compared to other connectors in my experience. On the expensive side, but worth the money.
The only problem with product like these are the enormous stresses they tend to put on to the Jack sockets could well rip them from the circuit board or damage the internal contacts. Therefore we cannot recomend them. A far better solution is to use flexible full sized to mini jack converter cable.
post-12772663
Post #20,899 of 40,447
audi0nick128
Northern Germany
Northern Germany
Th
I always knew using this wasn't ideal... But hearing it from you makes my OCD level go up :wink: but in a stationary setup, with something to support the weight, it isn't that bad, right? Just say yes...
Something different, I remember you saying you were driving highly efficient Horn speakers sufficiently direct from MOJO. Did you try the
Klipsch RP-160M, maybe?
Cheers
post-12772671
Post #20,900 of 40,447
GreenBow
Can anyone recommend a good 3.5 to Quarter inch plug adapter to plug my headphone into Mojo quarter inch headphone jack. Thanks in advance.
Yeah I would take @Mython's advice. Buy one like the Grado Mini-Adaptor Cable. It's peace of mind that your gadget sockets are not under pressure. It's quality. I bought one and I never looked back.
post-12772879
Post #20,902 of 40,447
florence
Is there anyone using Oriolus + Mojo combination out there? Waiting for the iem to arrive and I am curious how they will sound. Coming from Velvet btw.
post-12772941
Post #20,903 of 40,447
Arpiben
Th
Fully agreeing on connectors stresses, but dealing with a mobile device why not design a casing avoiding/reducing all Ins & Outs movements ?
It should not cost a lot more...
IMHO, it is the only way to get ride of stresses since all sockets are mounted by soldering contacts.
Just thinking in terms of future improvements, not complaining at all
Rgds
post-12772951
Post #20,904 of 40,447
anoutsos
I have just received my Mojo and, although I have read the manual carefully, I could not find any information on using two completely different headphones plugged in at the same time. I am currently using the DT880s (250 Ohm) and I am worried that if I also plug my Sony MH1C earphones (15 Ohm) into the second output the Mojo will send too much current through that output (at listenable levels for the DT880s). I guess I cannot control the volume separately, if the earphones sound too loud, right?
Thanks,
Aris.
post-12772955
Post #20,905 of 40,447
Mython
Thanks,
Aris.
You won't harm Mojo, but yes, if one is pair of cans is loud, and the earphones are quiet, there's no magic solution - the closest thing you could do, is to buy a basic inline volume control lead, to reduce the volume on the IEM side of the equation:
https://www.amazon.com/Koss-155954-VC20-Volume-Control/dp/B00001P4XH
https://www.amazon.com/Stellar-Labs-35-4180-Headphone-Control/dp/B008DJTB32
Not exactly audiophile, but it won't harm Mojo or your IEMs.
post-12773000
Post #20,906 of 40,447
Arpiben
No harm as you said, but headphones will sound differently vs plugged alone.
When plugging two headphones with different impedances Mojo sees an equivalent impedance for its single 'amplified' internal equals to (Z1*Z2/(Z1+Z2)); Depending on headphones you may have interactions between them ( reactive part ).
Therefore no harm but probable modifications in sounding vs single output.
Rgds
post-12773005
Post #20,907 of 40,447
Mython
It would certainly be a compromise - as I said; not an audiophile solution.
But a compromise that'd get the job done without any tears before bedtime
Reactions: Arpiben
post-12773158
Post #20,908 of 40,447
miketlse
@Peter Hyatt and his wife use the Mojos two ports, to enable them to listen to music together, but each of them with their own pair of beyer AK8is.
They find It works ok, without any issues. http://www.head-fi.org/t/779847/astell-kern-beyerdynamic-ak-t8ie-review-first-impressions-from-ifa-2015/630#post_12665723
post-12773175
Post #20,909 of 40,447
jmills8
Previously known as bmiamihk
Hong Kong and Miami
Hong Kong and Miami
post-12773202
Post #20,910 of 40,447
Norway
Norway
My take on the Mojo for those who might be interested:
http://www.head-fi.org/products/chord-mojo/reviews/16576
Users Who Are Viewing This Thread (Users: 2, Guests: 11)
  • Top
