Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12762166
Post #20,731 of 40,464
discord76
Will this adapter be good for connecting c coaxial digital input to the Mojo?
http://www.misco.co.uk/product/154251/C2G-3-5mm-Mono-Male-To-Rca-Female-Adapter
post-12762675
Post #20,732 of 40,464
NaiveSound
In order to get Apple music (only using that because 3 months free) to transport to mojo in bitperfect, can I get an app? Or is apple music not have a way for uapp or others? Just want vest quality when using mojo
post-12762764
Post #20,733 of 40,464
Torq
Seattle, WA
Seattle, WA
If you're using an Android device with Apple Music, then you're stuck with having Android's native, forced, re-sampling in the way and you won't get bit-perfect output.  There might be ways around that if you're willing to root the phone, but I'm not aware of any at the moment.
UAPP doesn't support Apple Music and I very much doubt Apple are going to open up their system to allow it to do so.  That they let Sonos integrate directly was really down to the level of penetration that product line has - and I think they're the only third party with access at the moment.
If you're using an Apple device, then the native stream goes straight to the Mojo and there's no resampling - so the result will be bit-perfect.
post-12762824
Post #20,735 of 40,464
Traveller
  My CD player just has a coaxial digital output is there a way to plug it into a Mojo? Also my computer is an Intel NUC, it has an HDMI output could I use that?
Yes, you can use your CD player as a "transport" by connecting it to the Mojo. Depending on your player, you'll either need an RCA to 3.5mm "Y" cable or a 3.5-3.5mm cable.
https://www.headphone.com/collections/cables/Mini-to-RCA-Cable
No, you cannot use an HDMI interface with Mojo.
post-12763331
Post #20,736 of 40,464
discord76
A "Y" cable is no use as it will have two RCA plugs and the 3.5mm will be stereo not mono. It seems hard to find a 75 ohm 1 RCA to 3.5mm cable.
post-12763375
Post #20,737 of 40,464
x RELIC x
The West Coast, Canada
Contact Dysonaudio and have them make you one. Reasonable prices and good quality.
https://www.dysonaudio.com/collections/digital-cables/products/new-handmade-dyson-audio-fiio-ibasso-dap-dac-hp-amp-75-ohm-digital-jumper-ts-rca
Or the adaptor you linked may work. For £2.19 you may as well just try it out.
post-12763530
Post #20,738 of 40,464
Traveller
My bad - I have the opposite setup (line out to preamp analog) which is why I had the "Y" component on my mind... .
I am currently using TOSLINK for CD-Player output but I could also go with coax, in which case it would be single RCA to mini.
I recommend Kimber Kable. You appear to be in the UK so I would suggest Russ Andrews:
http://www.russandrews.com/eu/cables-kimber-kable-interconnects-digital-audio-interconnects-digital-coax-interconnects/
Even comes with a Mojo-Quick-Start "guide"
p.s. I'm not a big fan of adapters.
post-12763701
Post #20,740 of 40,464
Mojo ideas
Member of the Trade: Chord Electronics
Swiss National Day - a little present for you.
I made a Mojo SD card adapter thanks to my new 3D printer. Was a bit tricky to find the right measurements for the top plate/plugs. It's a USB hub/SD Card reader that works fine with Android:
You can print it yourself, need some soldering experience, find the infos here:
https://www.thingiverse.com/thing:1698550
would be fun to see other adapters for the mojo, have fun.
Nicely done I like the colour too but I should say we've no plans at present match it.
post-12763732
Post #20,741 of 40,464
Ra97oR
CanJam London 2016 Karting Champion
I guess only hot pink is down in the pipeline at the moment.
post-12763783
Post #20,742 of 40,464
SearchOfSub
Thinking about getting Ether C to pair up with Mojo. Anyone have this setup how does it sound together?
post-12763921
Post #20,744 of 40,464
Mython
John, please, please, please can you have Chord make one to match this?
http://www.head-fi.org/t/720512/obscure-chinese-daps/1200#post_12699625
(joke - for god's sake, please don't!
post-12763950
Post #20,745 of 40,464
miketlse
I can only presume that the DAP is aimed at the female market sector (soft curves, fits comfortably in the hand, .....)
It is very different to many DAPs on the market, which have a very oblong box shape, with plenty of hard edges, plus plenty of buttons and a large display - overall a more macho styling to the physical design.
Users Who Are Viewing This Thread (Users: 2, Guests: 16)
