x RELIC x
Thanks for your clear explanation. So I can use either TRRS to TS cable or TRRS to TRS cable to connect FiiO X3ii and Mojo, right?
To be absolutely clear, not in stock form for a regular TRRS to TRS. You need a custom cable made to make sure the wires are soldered properly. Dyson Audio will know what to do.
Here is the pin-out for my cable for the X5ii to Mojo using the coaxial out of the FiiO DAP:
Again, if you want right angle connectors and the metal TRS plug looks better to you then you just have to specify that and Dyson Audio will be able to solder it properly.
