Hello, Just buy a Mojo, fantastic sound, object, possibilities but sad that it dosn't work with Spotify..
Spotify works no problem with Mojo using my iPhone 6S. Also, Spotify WASAPI also works fine with Mojo on my Surface Pro 3.
Oh, i see now.
- How i use tidal through UAPP? have some step-by-step to use it?
- Another thing... do you know if can DOWNLOAD TIDAL music, and get the music to save on the SD to listen on UAPP or ONKYO?
Pretty straight forward, open uapp and select tidal.
You can only play streaming music or music from your own library. Can't play saved music from tidal.
Sometimes the hype is just that....hype.
So don't get ruffled when folks see all the hoopla and over the top descriptions and cast a wary eye on it.
That wary eye makes it bit more special when the item matches the hype.
I took this pic with the IEM still in my ear. That pretty much says it all.
I'm not interrupting a 24/192 of Aerosmith's - (Mama Kin') just to take a pic. I can do both at the same time
Nice bro!
Have you try do something like...
- Download the offline song on ( tidal )
- Try to find the ( folder ) where is this downloads offline and ( move/copy ) to some folder where the UAPP or ONKYO can read and play?
* I guess need some App folder ( as root ) to get access to all folders on the android, and maybe find where is the folder where is the offline songs on tidal, what do you think about bro?
Hey everyone!
I think I may have found a solution to those who are experiencing EMI and static when streaming their music. I bought this thing called 'RadiSafe'. I attached it to the back of my phone and to my surprise I no longer hear static when my phone is placed on my desk. Normally when someone sends me a text or email I hear a static but now I do not. Next I tried opening up Tidal and Spotify and still no static. I even tried stacking the two of them and once again NO STATIC!
So if anyone is having issues with static give it a try.
http://www.ebay.com/itm/RadiSafe-Cell-Phone-Laptop-EMF-Electormagnetic-Radiation-Protection-Free-Ship-/141589598934?hash=item20f765d2d6:g:qPwAAOSwRLZUC2AE
Looks pretty much like snake oil to me. Good luck!
Let's put it this way ... IF it works all, it's also, by definition, blocking the signal from your phone on the side that it's applied. That'll clobber reception, and cause the phone to raise the gain on the radio amplifiers to try to compensate ... which will result in more heat and a sizable drop in battery life!
Nice analysis, everything has a cause and effect
No sound with my Zenphone 2 Ze551 ml using Spotify app, to succeed i have to plug usb between phone and Ibasso dx80 and coax from Ibasso to Modjo, a little complicated...Spotify works no problem with Mojo using my iPhone 6S. Also, Spotify WASAPI also works fine with Mojo on my Surface Pro 3.
No sound with my Zenphone 2 Ze551 ml using Spotify app, to succeed i have to plug usb between phone and Ibasso dx80 coax and coax from Ibasso to Modjo, a little complicated...
Go to developer option, it might be possible, the USB Audio option is disabled.
