eenecho
- Dec 11, 2015
Is there any possibility to connect the iPhone 4s or iPod Classic 5 Gen. to Mojo?
Absolutely. The 30-pin camera connector works with the iPhone 4 without issue; cannot confirm iPod.
There're not enough pants in the world for Dave.
Time for you to join the nude side my friend.
Can someone tell me if i'm right, i heard there are ~125dm of volume in the mojo. I count 95 clicks until the lights lock on whitish purple and don't change anymore. That would mean each click is ~1.3db, which would mean I listen at about 17-20db(13-15 clicks) with my ADEL A12's. Is that correct?
How would you put that in your pants pocket?Arpiben the volume required to reach a certain dB level will rely heavily on the mastered volume level of the track. Most modern pop songs may need around 10 clicks less than a well recorded older track mastered at a lower level. Chord can't give a guideline as there are entirely too many variables to weed through for every track and every headphone for every user.
For me, I listen to the ETHER C (22 Om, 92 dB) at 35 clicks from zero on average and I've measured (with a spl meter app from my smartphone - which certainly isn't the most accurate) an average reading of anywhere around 75-80 dB (with peaks from 85-90) with most of my tracks. Some tracks I go up about 5 clicks and some I go down about five clicks, based solely on my listening comfort level.
The JH Angie (17 Ohm impedance, 117 dB) I listen at around 15 clicks from zero which gives me an average level roughly around 80 dB on most tracks. Again, depending on the track's volume I'll adjust the level up or down a couple clicks.
I want to re-iterate that this is with my headphones/IEMs and my ears and comfort level, yours will likely vary. If you are concerned then you should get a spl meter (an actual spl meter, or at least smartphone app) to measure what your output is through the headphones/IEMs. The smartphone app may not be super accurate but it should get you in the ballpark. Just make sure to place the mic right at the IEM nozzle or in a sealed ear cup for the best measurement.
haha, I put an angled connector so I can slide it inside my pocket. Top of phone down.I don't. Good for around the house when I'm not tied to my desk (I work from home). :wink_face:
@Arpiben the volume required to reach a certain dB level will rely heavily on the mastered volume level of the track. Most modern pop songs may need around 10 clicks less than a well recorded older track mastered at a lower level. Chord can't give a guideline as there are entirely too many variables to weed through for every track and every headphone for every user.
