Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. x RELIC x Contributor
    Someone just asked about how the Noble BTS paired with the JH Angie so I tested it. All I will say is that it sure is convenient. :wink:
    Next, for reference, I plugged the Angie in to the iPhone 5S and was floored at how bad it sounded compared to what I've been used to with the Mojo. Bloated bass, edgy / undefined treble, flat mids, flat soundstage. I really don't remember the iPhone 5S sounding this bad. Once again, after acclimating to a certain level of quality it's nice to remind the brain what it used to think sounded... not bad. Plugging back in to the Mojo was like coming home.
  2. Light - Man
  3. PinkLemonade
    Hi! First post here. Wow, what a thread I must say!
    The reason I'm writing here is because I'm about get a Mojo for personal use mostly, but I'm playing in a band and we're using in-ear minitoring, so I'm wondering if I can use it to connect from a mixer (AUX-output XLR) to the Mojo somehow. I assume it would be analog to digital since Mojo doesn't have an analog input, does that even work??
    Link to mixer:
    http://www.sweetwater.com/store/detail/XR18
    Thanks!
  4. music4mhell
    Hey Guys,
    I just received some small ferrite cores for my micro USB to Micro USB OTG cable.
    Could you please suggest which side i should clip this ferrite core, the micro usb side of Mojo or the micro usb side of my Source/mobile ?
  5. jellofund
    Just bought another Mojo and wondered if I could ask a quick question re. the line out when I want to use as a DAC to feed another amp?
    I know that holding down both volume buttons during power up sets a fixed output of 3Vrms and that you can swap to 1.9Vrms with 4 clicks. Possibly a silly question but is that 4 clicks of both buttons or just the vol down button?
    Thank you :)
  6. Blasyrkh
    volume down
    jellofund likes this.
  7. jellofund
    Brilliant - thanks!
  8. Rob Watts
    Since you said cores, I would do it both ends...
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
    onsionsi likes this.
  9. felix3650
    Hey everyone,
    Mojo owner here. Does anyone know what's Mojo's output power at a 50ohm load? If so, is it in RMS value or peak power?
    I'm away from the lab I used to work so can't make measurements myself. Probably @Rob Watts can help me here[​IMG]
    Enjoying the sound quality of the Mojo since 3 months now, both on my notebook (toslink optical) and Galaxy S5 (USB OTG)
    Felix
  10. xtr4
    Be mindful that once you've adjusted to 1.9V, the Mojo remembers the position you set, so when you power it back on normally, it'll still output 1.9V. This is a gentle reminder so you don't accidentally kill any of your equipment and your ears
  11. Rob Watts
    I have done a quick measurement; with 30 ohms it is 4.25v RMS so that is 600 mW. For 50 ohms, I would expect 4.6v RMS or 423 mW RMS. This is with Mojo in blue battery, and at 1% THD with a continuous sine wave, power is RMS.
    Rob
  12. music4mhell
    Thank YOU very much ROB for the quick reply.
    Thank you :) I will use 2 Ferrite cores then one on each end of Micro USB cable.
  13. AndrewH13
    I was thinking these faces[​IMG]
    x RELIC x likes this.
  14. jellofund
    I had a Mojo just after launch so was aware but I appreciate the heads up!
    My Pandora Hope VI would likely be fried by 1.9V so always ensure to reset the volume before I power off. I'm sure it's the sort of mistake you'd only make once :D
  15. vaibhavp
    This will be my last post here as i am in process of obtaining a review sample. Will write my further findings there. Also ppl are too defensive here and dont intend to disturb natural order here.
    My point is, anything thats not music, be it shifting of chair, chatter from public, cough etc is reproduced with startling clarity in mojo.
    But i think it almost starts taking center stage, beside music performance. This i find a bit unnatural. Cause obviously its minor sound and should be in background. This happened to me in most recordings. So no need for a list.
    I will review it and then take final call. Maybe i will find it different on longer listen. I have no doubt mojo is excellent in what it does well.
    Cheers
